mikeyboy1966 Posted June 14, 2023 Share Posted June 14, 2023 I’d welcome your thoughts on small ribs. im looking for something @3metres ish. It needs to have a centre steer position with seats side by side. I could buy new,2.4 metre with a good s/h 10 hp Honda ,then source a good trailer for prob £5.5k.(this would fit perfectly weight wise with my boat) or,any thing used between @£3 to £6 k and up for an old to newer boat/outfit. im obviously looking online at everything I can find coming onto the market but I’d welcome views and experience on rib ownership. id sell my day boat and put the rib on davits, id also add,it’s not a need,more of a want thing. Quote Link to comment Share on other sites More sharing options...
Happy Posted June 15, 2023 Share Posted June 15, 2023 Hi. Cannot really advise on make/type there is so much to choose from. We had a rib and outboard which we hung from davits on our Seamaster 30. My only advice - be careful with the weight. Best of luck Quote Link to comment Share on other sites More sharing options...
Smoggy Posted June 15, 2023 Share Posted June 15, 2023 Check what is supporting the davits, with just an 2.5m airdeck flubber and yamaha 8hp 2 stroke my RLM31 had a davit pull down through the deck on a bumpy sea trip, had to repair grp then add bigger spreader pads above deck and lots of steel angle below deck to brace it all. I have a 2.75m rib in my garden but it's not centre console just regular tiller and perch on tube type, good rib but quite old, it has a flat floor (double skin hull) which makes it really quite heavy. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted June 15, 2023 Share Posted June 15, 2023 Do you mean a proper RIB? = Rigid Inflatable Boat. That is a GRP hull and inflatable side tubes? or an inflatable boat with a solid transom. Very different animals in every respect, especially weight if going on davits. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted June 15, 2023 Share Posted June 15, 2023 I work with 2 guys that talk about their ribs but can't seem to explain to them the difference, they have dinghies not ribs.... I have airdeck flubber on the boat so I can stow it below deck when not in use and snap davit to the back in summer use. Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted June 16, 2023 Author Share Posted June 16, 2023 On 15/06/2023 at 08:45, ChrisB said: Do you mean a proper RIB? = Rigid Inflatable Boat. That is a GRP hull and inflatable side tubes? or an inflatable boat with a solid transom. Very different animals in every respect, especially weight if going on davits. I’m looking at a 2.4 metre Cabrio kart. it has a grp hull ,centre steer and a bench seat,plus bow seat. it weighs 50kg so with a 10 hp outboard it would be just under 100 kg Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted June 16, 2023 Author Share Posted June 16, 2023 This is the 2.7 metre model ,but you get the gist. Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted June 16, 2023 Author Share Posted June 16, 2023 Drop down to a 6/8 hp motor it would be @75 kg Quote Link to comment Share on other sites More sharing options...
