Formica
RegalSafari
Hi all,
i am currently replacing the flooring in the bathroom (heads), and some Formica around the sink. The original floor / shower tray cover was marine ply with Lino attached with contact adhesive. I am replacing the pale yellow with Matt white Formica. Do you think it's worth formicaing the floor panels, the area is about metre sq, or sticking to the original design Lino?
i was thinking Formica maybe a little slippy, but the finish would be good?
Any thoughts?
I've started a job I wish I didn't but the flooring was all rotten.
Dave
Formica is incredibly slippery underfoot when wet. Safest option for flooring would be non slip bathroom vynil  the stuff that is about 4 to 5 mm thick. Easy to  cut and shape and will look good too.
cheers
Trev
3 hours ago, Mowjo said:
That floor looks the same as on my last Hampton 25, I used an offcut of non slip floor vinyl, stuck down with a tub of B&Q vinyl adhesive, I even use it on toilet walls,,
Looks a nice job.
Yep the Formica in your boat look brill, thanks Griff I will have a look at the teak flooring it looks nice.
I think everyone could be right about Formica being slippy.
I made all the new templates yesterday, ready for me to pick a new covering. Before I commit to the finished article I am going to try everything at Easter. That's the down side of living further away from the boat.
its bad when your fitting a new bathroom on the boat, before your home. But that life when you love boating
Thank you for the offer Griff,
i ve just ordered the White Formica for the walls which Intend to fit during next winter, and ad-hoc to panels throughout the year.
Yep if you have a little spare that would be good, the area is just over 1 metre sq.
looking forward to Easter hope you also have a good one
Dave
