smitch6 Posted February 2, 2010 Share Posted February 2, 2010 hiya folks i have a birchwood 33 with 2 diesel ford 2700 straight 6 engines one works fine good as gold the other i am having problems with when i bought the boat the engines weren't connected no exhausts, fuel lines, electrics, starter etc was connected not even the morse cables so goodchilds connected most stuff for me and got 1 engine running cost me loadsa money but it ran anyway i'm trying to sort the other one out i have done all the fuel lines and spent all day bleeding the thing pumped diesel up to the fuel pump body thingy and then cracked each injector in turn and used the starter motor to try to force the fuel through i started at the back as it was easy to get to after i done 6, 5, 4 it ran not sure if that the right number but the back 3 anyway lol sorry anyway it ran the throttle was fully open and once it was running for a few seconds it went mad revved its guts out i tried to ease the throttle back but no change just kept screaming at me i pulled the stop out and it kept revving eventually after a mad few minutes it died now it won't start at all again i think i may have to bleed it all again hope that makes sense but basically i don't know alot about engines full stop especially a diesel but my 1st thought was injector pump faulty but it could be timing not set up as well any thoughts please as i said i don't know any condition of the engines as the whole boat has been a pain since we bought it a right bog job by the previous owner so i'm not sure what has been done before i owned it i'm based down waveney river cnt if anyone fancies having a look at it thanks steve Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 2, 2010 Share Posted February 2, 2010 You say despite throttle position it still revved it’s nuts off eh! To do that it must be getting more fuel than the throttle setting would normally give it. So it’s either the I.P. itself or possibly the pump is not responding to the throttle setting through jammed or broken components up to and including the main spindle lever. Possible inlet manifold air leak could give similar symptoms but the fact that even pulling the stop (that should instantly cut the fuel) didn’t shut the beast down points to the pump. I hate to add more woes but over revving cold with no load for any length of time may have damaged other bits so be vigilant for unusual noises and keep an eye on the instruments when you do get it going again. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted February 2, 2010 Author Share Posted February 2, 2010 mmmmm instruments there isn't any of them at the minute apart from an amps gauge thats something else i need to sort out for both engines as i said there was nothing when i bought the boat i did think injector pump faulty but as i'm not a mechanic it is only a guess i think i could do with a friendly man who knows diesel engines to come and have a look for me any offers?????????? i'll even say please lol Quote Link to comment Share on other sites More sharing options...
jimbo Posted February 2, 2010 Share Posted February 2, 2010 When you say the engine wouldn't stop and was revving uncontrollably, it sounds to me like it might have been finding its own fuel from somewhere? Like engine oil! Blown headgasket is a real possibility Quote Link to comment Share on other sites More sharing options...
smitch6 Posted February 2, 2010 Author Share Posted February 2, 2010 mmmmm thanks lol i sure hope not its hard enough to get at the side of the engine if it needs any major work i'm going to have to dismantle half the wheelhouse as we live aboard its not a good thing to have to do Quote Link to comment Share on other sites More sharing options...
jimbo Posted February 2, 2010 Share Posted February 2, 2010 I'm not saying it is definateley that! It maybe a problem with the injector pump as David has pointed out, but it is another possibility sadly. As a matter of interest, have you just changed the oil in this engine? As when I used to do oil changes on 1.9 Peugot diesels, sometimes the refilling of the engine oil would lead to a small amount of oil getting into a breather pipe on the filler neck, this would sometimes result in the engine having a good rev to itself untill the oil had been exhausted. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted February 2, 2010 Author Share Posted February 2, 2010 no i haven't done anything to it all apart from bleed the fuel system and get the starter recond which wasn't a bad price had it done at lowestoft cost me around £80 i think completely redone brill job too Quote Link to comment Share on other sites More sharing options...
Stranger Posted February 3, 2010 Share Posted February 3, 2010 just a guess steve but the engine wasent running backwards was it as a diesel can do sometimes on a 2 engine boat the drive on both engines are usually opposite direction this can be done via a hydraulic gearbox but some engines are designed to run in the opposite direction John at Maffett Cruisers has this set up on his own boat with twin perkins engines might be worth having a word with him as an emergency stop you need to block the inlet with rags keep your hands clear as you wont get them off the manifold and serious injery wil occur Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted February 3, 2010 Share Posted February 3, 2010 It would also be worth checking the oil is not overfilled, I had this problem on a breakdown, I went to start the engine and it revved uncontrollably and chucked a load of oil out of the exhaust. I thought the thing had blown up but after working out what had happened I pumped the oil out to the correct level ( into the spare oil can ) and started the engine which ran fine. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted February 4, 2010 Author Share Posted February 4, 2010 its still drawing air in from somewhere so i've got to find out where first also there's no rocker cover gasket i discovered yesterday while trying to bleed it i noticed smoke coming from where the gasket should be and it looks like there nothing there that wouldn't do it a lot of good when i do finally get it started trouble is its such and old engine i think i'm going to struggle to find one does asap do a roll of cork gasket its a big ford 2700 6 cyl if anyone knows of where i can get one from? i'm going to have to crack every joint and reseal it again strange because they all look solid enough but i know with diesel its only got to be a tiny hole a friend had a look yesterday and said he thinks the injector pump has been replaced as the other engine its been painted green but this one is still metal so i wonder what has happened and whether its been set up at all the throttle doesn't feel the same on that side as the other it feels as though the 1st half is dead and just connects right at the end both sides were put together by goodchilds so i'm hoping it is set up right i could really do with someone who knows these engines as i'm sure they'd look at it and say o its only this Quote Link to comment Share on other sites More sharing options...
Guest chriscraft Posted February 9, 2010 Share Posted February 9, 2010 My best guess is an air leak,her,s a usfull link, http://www.motoren.ath.cx/download.php? ... _parts.pdf Quote Link to comment Share on other sites More sharing options...
smitch6 Posted March 24, 2010 Author Share Posted March 24, 2010 well a small update to my engine problems fuel injector pump is the problem definitely i rung a friend and he suggested colchester fuel really helpful ppl there i will say and i explained what was happening and he said a really common fault on them pumps, the springs corrode and snap and hey presto exactly my symptoms only cure a complete rebuild unfortunately they wouldn't say how much because he said it could just be new springs or it could be a lot more but they did say time the engine to no1 first that way its easier to replace so at some point i'm gonna have to time the engine and take it off and have a run out to colchester a few times i'll have fun trying to do that the engine is really big and hard to get to as usual it couldn't be the other one i can get at that lovely Quote Link to comment Share on other sites More sharing options...
Guest Posted March 24, 2010 Share Posted March 24, 2010 I know you might not want to hear this, but I would strongly reccomend that you get the govenor spring checked on the other pump as well ! My friend has just had the same problem, had the other pump checked and the spring was on its last legs. Also dont forget to fill the pump with oil (engine oil) after fitting ! Bye the Bye air leaks on diesels are a swine to find as they can leak air in without leaking fuel out ! Quote Link to comment Share on other sites More sharing options...
