Guest Posted February 24, 2010 Share Posted February 24, 2010 Hi again while we were aboard curlew over Christmas we found that when going from forward to revers & vice versa curlew wanted to stall so we had to give her move revs so she dint get the chance. we found out shes does not have this issue while out of gear & are wanting to get this sorted while were down in April any suggestions? Jonny Quote Link to comment Share on other sites More sharing options...
puddlejumper Posted February 24, 2010 Share Posted February 24, 2010 something round the prop? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2010 Share Posted February 24, 2010 something round the prop? mmmm Quote Link to comment Share on other sites More sharing options...
Julz Posted February 24, 2010 Share Posted February 24, 2010 Time to get your swimming trunks on Jonny, and take a sharp pair of sissors down there to try and sort it out or maybe have her lifted out for a good bottom scrub and sort out any other problems at the same time Julz Quote Link to comment Share on other sites More sharing options...
jimbo Posted February 24, 2010 Share Posted February 24, 2010 When was it last out of the water Jonny? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2010 Share Posted February 24, 2010 When was it last out of the water Jonny? Hi Jim well not since we have had her the previous owner had her out every winter on the hard stuff he replaced the prop shaft that i know of. we are getting some quotes from Richo's to get some work done in a couple of weeks & in to the winter so i think pulling her out will be last on the list with an anti foul buff & polish. we do have a weed trap to stuck our hand down to the prop to check things are ok down there without lifting her out so i will let farther do that while i am not aboard dont want the water to flow in Jonny Quote Link to comment Share on other sites More sharing options...
Guest chriscraft Posted February 24, 2010 Share Posted February 24, 2010 Hi Jhonny, ypur engine troubles may be something to do with your lack of hot water,ie if your thermostats stuck open it could cause BOTH problems?cool running engine producing no hot water? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2010 Share Posted February 24, 2010 Hi Jonny, Is there any way you can get hold of the prop shaft and turn it by hand? Does it turn easily? When underway does the boat rev to its max and produce top speed without the engine labouring or producing any strange noises? Either of these should rule out something wrapped around the prop. Rod Hi Rod while moored at Loddon a couple of years back i noticed that when gunning it a little you could feel the bow rise a little & you would notice the prop wash was qwite a bit for low revs. but now you have to rev a little higher to get to say 4mph i have noticed a difference but no knocking or clunking noises. Jonny Quote Link to comment Share on other sites More sharing options...
Happy Jax 3 Posted February 24, 2010 Share Posted February 24, 2010 Hi Jonny As Rod has said see if you can turn the prop shaft by hand when you are in neutral. If not, it does sound like you may have something around the prop causing resistance. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2010 Share Posted February 24, 2010 Hi Jonny As Rod has said see if you can turn the prop shaft by hand when you are in neutral. If not, it does sound like you may have something around the prop causing resistance. thanks for the advice everyone ill get dad to dunk is hand done if its long enough but knowing my luck it it will be time for a swim but hay its boating Jonny Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted February 24, 2010 Share Posted February 24, 2010 if when in gear there is vibration when you stand aft that is a good sign of something down there, perhaps your tickover is just set too low. Quote Link to comment Share on other sites More sharing options...
Boaters Posted February 24, 2010 Share Posted February 24, 2010 Colins your man for clearing a prop Jonny ,he will tell you how he did it Quote Link to comment Share on other sites More sharing options...
newf Posted February 25, 2010 Share Posted February 25, 2010 You beat me to it Roy Quote Link to comment Share on other sites More sharing options...
Happy Jax 3 Posted February 25, 2010 Share Posted February 25, 2010 Colins your man for clearing a prop Jonny ,he will tell you how he did it Would have to be at least May before I jump in again Roy Quote Link to comment Share on other sites More sharing options...
Guest Posted February 26, 2010 Share Posted February 26, 2010 After our holiday in Egypt last week I now have a snorkel and mask. I just need to make the snorkel a little longer. Jonathan Quote Link to comment Share on other sites More sharing options...
thirdmate Posted February 26, 2010 Share Posted February 26, 2010 On most boats clearing the prop is ALWAYS the Skipper's job Quote Link to comment Share on other sites More sharing options...
