Starbrite Posted July 12, 2018 Share Posted July 12, 2018 Can anyone tell me what size prop shaft is on a connoisseur 38 I want to put a rope cutter on any advice appreciated Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
Smoggy Posted July 12, 2018 Share Posted July 12, 2018 The boat model alone may not help as it may have been re-engined at some time and had a stern gland changed at the same time. You can't beat a vernier across the shaft, metric and imperial can be very close but not close enough to keep a rope cutter clamped. A stripper should be matched to number of blades too (although mine are not). Quote Link to comment Share on other sites More sharing options...
Starbrite Posted July 12, 2018 Author Share Posted July 12, 2018 The boat model alone may not help as it may have been re-engined at some time and had a stern gland changed at the same time. You can't beat a vernier across the shaft, metric and imperial can be very close but not close enough to keep a rope cutter clamped. A stripper should be matched to number of blades too (although mine are not).It has a bmc 2.5 engine I wanted to order a rope cutter before I have it lifted to remove something I've got on the prop is the shaft the same size as the shaft that leaves the hydraulic drive? Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
Vaughan Posted July 12, 2018 Share Posted July 12, 2018 57 minutes ago, Starbrite said: is the shaft the same size as the shaft that leaves the hydraulic drive? Yes. It will also have a standard length keyed taper, according to the shaft size, so as to fit standard propellors. I believe Connoisseur fitted shafts of 1.5" diameter to these boats. In my experience, a cutter will not be of any benefit to you, on the Broads. You say you have something on the prop. It may just be a plastic shopping bag. Quote Link to comment Share on other sites More sharing options...
Starbrite Posted July 12, 2018 Author Share Posted July 12, 2018 Yes. It will also have a standard length keyed taper, according to the shaft size, so as to fit standard propellors. I believe Connoisseur fitted shafts of 1.5" diameter to these boats. In my experience, a cutter will not be of any benefit to you, on the Broads. You say you have something on the prop. It may just be a plastic shopping bag.Thanks for that my boat is in Yorkshire and I've picked up a bag with some clothes in it as I've got a piece of white plastic and part of a tee shirt off so far Sent from the Norfolk Broads Network mobile app 1 Quote Link to comment Share on other sites More sharing options...
oldgregg Posted July 13, 2018 Share Posted July 13, 2018 I assume the boat is one of these? http://www.broads.org.uk/wiki/index.php5?title=Style_Details&style=CC37 Quote Link to comment Share on other sites More sharing options...
Starbrite Posted July 13, 2018 Author Share Posted July 13, 2018 I assume the boat is one of these?http://www.broads.org.uk/wiki/index.php5?title=Style_Details&style=CC37Yes No. 109 bought it last September Sent from the Norfolk Broads Network mobile app 1 Quote Link to comment Share on other sites More sharing options...
Starbrite Posted July 13, 2018 Author Share Posted July 13, 2018 I assume the boat is one of these?http://www.broads.org.uk/wiki/index.php5?title=Style_Details&style=CC37All sorted charity bag and 2 tee shirts around propeller and shaft now removed thanks for all the info Sent from the Norfolk Broads Network mobile app 2 Quote Link to comment Share on other sites More sharing options...
oldgregg Posted July 13, 2018 Share Posted July 13, 2018 It is amazing the things that find their way into the rivers! Quote Link to comment Share on other sites More sharing options...
