Using The Grill
Andrewcook
Most of the grills on smaller two burner boat cookers tend to be a little erratic I have found, you can normally squeeze in two slices of bread under the grill, this can seem to take an age to toast, you turn your back for just a second and the whole lot has turned to charcoal.
At the end of the day you’re on a boat so the chances of a full sized oven and grill are likely less. 😊
Agree never used WRs grill for toast just a waste of time.  Best to buy those part cooked rolls and put in oven!
WRs oven and hob could cook roast pork and all the trimmings for up to 8 people but the best use of the grill SPACE is to heat plates!!!
