Ray Posted July 27, 2022 Share Posted July 27, 2022 Could someone advise me please on the correct fluid to top up with. Broom 29 1995 Filler directly behind wheel. Quote Link to comment Share on other sites More sharing options...
Vaughan Posted July 27, 2022 Share Posted July 27, 2022 Ideally, do not use red oil, as this may eat away at the rubber seals in the piston. The best is white oil as used in hydraulic drives, such as Total Equivis. The same as used in farm machinery. I have been told that the two do not mix, so if you already have red oil, then continue with it. It is ATF or TQF. Can't remember which. 1 Quote Link to comment Share on other sites More sharing options...
dnks34 Posted July 27, 2022 Share Posted July 27, 2022 I have used this: https://www.asap-supplies.com/products/vetus-hydraulic-oil-for-steering-systems-sold-per-1-litre-bottle-v-vhs1 1 Quote Link to comment Share on other sites More sharing options...
annv Posted August 1, 2022 Share Posted August 1, 2022 Hi If you go to a farm machinery outlet you can get top quality oil ATF a lot cheaper in Lt or 5Lt containers. do not use red as this is a TQF for automatic gearboxes ( Borg Warner Velvet Drive). John 1 Quote Link to comment Share on other sites More sharing options...
