Mouldy Posted January 17 Share Posted January 17 From the BA website: https://www.broads-authority.gov.uk/__data/assets/pdf_file/0022/454090/NTM-01-of-2023-Temporary-closure-of-Sutton-Staithe.pdf Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted January 17 Share Posted January 17 Oh dear, the over stayers wonβt be happyΒ Griff 2 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted January 18 Share Posted January 18 Last time I was there, it certainly needed dredging. Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted January 18 Share Posted January 18 Looks like Neatishead will be closed as well maybe busy South bound on The Ant.Β Regards Marge and PargeΒ Quote Link to comment Share on other sites More sharing options...
Mouldy Posted January 18 Author Share Posted January 18 13 minutes ago, MargeandParge said: Looks like Neatishead will be closed as well maybe busy South bound on The Ant.Β Regards Marge and PargeΒ This might compound the problems: https://www.broads-authority.gov.uk/__data/assets/pdf_file/0027/454095/NTM-02-of-2023-Dredging-on-the-Upper-River-Ant.pdf 2 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted January 18 Share Posted January 18 I bet we will all find our boats easier to steer after that, as the "squat effect" of the narrow river will be greatly reduced by having deeper water. Quote Link to comment Share on other sites More sharing options...
FlyingFortress Posted January 18 Share Posted January 18 2 hours ago, Vaughan said: I bet we will all find our boats easier to steer after that, as the "squat effect" of the narrow river will be greatly reduced by having deeper water. Squat is a function of the square of the speed so at 4 MPH , squat will be minimal. The only way your steering will be effected is by shallow water effect which has nothing to do with speed hence not squat. Squat, a very misunderstood and while quite real, effect. Squat, perversely sucks down your vessel to a deeper draft when you navigate in shallow water. Shallow water effect interferes with the flow of water around the rudder and happens regardless of speed. I can explain more but it is rather complicated π³ Bank effect caused by narrow rivers is something quite different although the hydrodynamic causes are very similar. Quote Link to comment Share on other sites More sharing options...
Vaughan Posted January 18 Share Posted January 18 Oh dear, I'm sorry I spoke. Β Β Β 1 Quote Link to comment Share on other sites More sharing options...
rightsaidfred Posted January 18 Share Posted January 18 25 minutes ago, FlyingFortress said: Squat is a function of the square of the speed so at 4 MPH , squat willΒ Squat, a very misunderstood and while quite real, effect. Squat, perversely sucks down your vessel to a deeper draft when you navigate inΒ Β Does that mean if we raise the river bed at PH boats will get through. Fred 2 Quote Link to comment Share on other sites More sharing options...
FlyingFortress Posted January 18 Share Posted January 18 6 minutes ago, rightsaidfred said: Does that mean if we raise the river bed at PH boats will get through. Fred πππ Quote Link to comment Share on other sites More sharing options...
FlyingFortress Posted January 18 Share Posted January 18 But only if you take the blooming bridge with it π 3 Quote Link to comment Share on other sites More sharing options...
