JawsOrca Posted March 20, 2015 Share Posted March 20, 2015 Hi All, I need to oil the swimdeck and I'm not paying for marine grade products! (Toolstation special!), but what should I use; teak or Danish oil? It seems Danish oil is internal only? Any tips, The would is Balau if that means anything lol! Quote Link to comment Share on other sites More sharing options...
LadyPatricia Posted March 20, 2015 Share Posted March 20, 2015 Only tip from me, or Deb actually, don't get teak oil on the gel coat ....... It's a pain to get off 1 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted March 20, 2015 Author Share Posted March 20, 2015 Steve/Debs.. Knowing me I will probably get it on everything else except the bit of wood!! 1 Quote Link to comment Share on other sites More sharing options...
BroadScot Posted March 20, 2015 Share Posted March 20, 2015 What about linseed oil? That would give it a good bounce! Just break it in with a cricket ball on a stick! Seriously Alan, I would think one of the Old Guard on here - I use that word old very loosly I may add- will assist you in the correct choice that doesn't cost an arm n a leg! Iain. 1 Quote Link to comment Share on other sites More sharing options...
stumpy Posted March 20, 2015 Share Posted March 20, 2015 I used Danish Oil on my mast last year and am well pleased with how its stood up to the elements. This spring a quick rub down with fine wire wool, a couple of coats dabbed on with a cloth and it looks good for another twelvemonth. Just make sure the cloth dries out properly before you bin it as they can combust apparently. 1 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted March 20, 2015 Author Share Posted March 20, 2015 lol Iain Thanks Andy, Do I need to rub it down each year? or can I just apply over the top? (I've only ever used oils once!). Thank's for the warning to, that sounds a bit scary! Quote Link to comment Share on other sites More sharing options...
BroadScot Posted March 20, 2015 Share Posted March 20, 2015 One other thought Alan would be Castor Oil. Dunno about the wood, but it would surely get you on the move quickly! Iain. 1 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted March 20, 2015 Share Posted March 20, 2015 Hi Alan,I have not used Danish Oil on the boat but I have used it on hardwood outdoor furniture, I apply it at least once per year and build it up using a few coats allowing plenty of drying time, I also used this on my dresser but it had over twenty thin coats. RegardsAlan 1 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted March 20, 2015 Author Share Posted March 20, 2015 Lol Iain! Is it going to be Castrol oil 5x40w next? no!! Although the chandlers seem to be selling linseed oil too... Thanks Alan, that looks lovely. I'm I right in thinking Danish oil is more like a polish/varnish than an oil? The swimdeck just needs protecting from the water really and I really don't want to have to varnish it every 5 mins! I also don't mind it not looking too pretty as long as the lasts a couple of years. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 20, 2015 Share Posted March 20, 2015 A few years ago, there was a very good group test of varnish versus oil in Practical Boat Owner. They concluded that Varnish will always give a more attractive and harder wearing finish, but that when time and effort was considered, oil was much quicker and easier, especially when recoating. I've tried everything over the years, and I've settled on varnish for interior woodwork, and oil for exterior. Interior varnish can last for decades, but when left outside in the open air and exposed to sunlight and weather, it flakes after a couple of years or so, no matter how carefully it's done, and even using the most expensive poly varnish. ...and there's the rub... if it has blistered, you have to scrape the whole lot off, sand, and then several new coats. Several days of heavy and dusty work. Whereas with oil, it never "flakes" because it has no hard skin. You just flat it down with sandpaper, and reapply. It can even be done with a cloth rather than a brush. So with varnish it's several days work, compared to a couple of afternoons with oil. I've used Deks Olje D1, and Sikkens Cetol Novatech, both recommended by the PBO test report. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted March 20, 2015 Share Posted March 20, 2015 Hi Alan, Danish Oil does soak into the wood on the first coat and dries to a dull sheen and unlike other oils does fully dry, I normally give the dried coat a light rub down with the finest wire wool and then wash down with a lint free cloth using meth's or white spirit, when full dry reapply more coats of Danish Oil, wire wool down the surface prior to the last coat. Regards Alan 1 Quote Link to comment Share on other sites More sharing options...
stumpy Posted March 20, 2015 Share Posted March 20, 2015 Alan, as Strowie and Ranworth say, I just gave it a slight 'flatting' and wiped more on, left overnight hanging in the shed then did the same again - total actual hands-on time maybe an hour. AND no need to worry about brush marks or runs! I could probably left it another year but it'd faded a bit in the sun on the top surfaces. 1 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted March 20, 2015 Author Share Posted March 20, 2015 Thanks guys . I'll grab some Quote Link to comment Share on other sites More sharing options...
Guest Posted March 20, 2015 Share Posted March 20, 2015 Alan, as Strowie and Ranworth say, I just gave it a slight 'flatting' and wiped more on, left overnight hanging in the shed then did the same again - total actual hands-on time maybe an hour. AND no need to worry about brush marks or runs! I could probably left it another year but it'd faded a bit in the sun on the top surfaces. Yes, oil turns the "touching up" of external wood from a long-winded chore into a pleasant few minutes task that can be done whenever it looks a bit faded. I used to keep an oil application rag in an air tight plastic bag and some disposable latex gloves aboard, so there wasn't even any brush cleaning required. Quote Link to comment Share on other sites More sharing options...
