Turnoar Posted September 3, 2021 Share Posted September 3, 2021 Here she is at the Herbert Woods book launch. I tried a ‘through the rigging shot’, not quite so spectacular broads style by yours truly... need to leave that to Beken’! She was definitely worth the full resto. I’ve got a closer up shot which I won’t post as it would probably id individuals but suffice to say she was fondly remembered by the alumni. Fantastic that the owner went the whole hog! Quote Link to comment Share on other sites More sharing options...
grendel Posted September 26, 2021 Author Share Posted September 26, 2021 Now I haven't posted in this thread a while, but that doesn't mean I have been idle, in fact I have been varnishing, and that's about as interesting as watching varnish dry. At last I have got to the point of adding fittings back, first was the new masthead light, a led one, I clipped the cable down the mast, carefully adding pieces under the clips to cushion the cables, looked at the red and black wires showing and didn't like it, ok time to raid through my brass bits, I had some tube, a bit chunky and would require new clips, then my eyes alighted on some 1/4" brass channel, this was fine in width, but looked too deep, so on the mill it went and the two flanges were cut down by 1mm, then cutouts were made for where it enters the mast at the top, and where it passed over the brass bracket holding the wings in place. The clips were modified to fit round the new section, and then it was all fitted, much better. 6 Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted September 26, 2021 Share Posted September 26, 2021 You will have to put a tin of Brasso onboard with all this bling. Quote Link to comment Share on other sites More sharing options...
grendel Posted September 27, 2021 Author Share Posted September 27, 2021 12 hours ago, BrundallNavy said: You will have to put a tin of Brasso onboard with all this bling. I will just borrow Griffs when I meet up with Broad Ambition. 1 Quote Link to comment Share on other sites More sharing options...
SteveO Posted September 27, 2021 Share Posted September 27, 2021 On 26/09/2021 at 21:00, BrundallNavy said: You will have to put a tin of Brasso onboard with all this bling. And a pair of sunglasses. Quote Link to comment Share on other sites More sharing options...
