Posted
What fitting is it? Butane I assume, I have a half full 13 bottle of similar age but can't find a fitting for it as it's 20mm not the usual 21mm and I think the depth is different from any 20mm fittings around.
If I could find the right fitting I could decant the gas into 4.5kg bottles.
Posted
Boulters may be able to help with the 20mm fittings…😎
Posted
1 hour ago, gancanny said:
No, that's a propane fitting, the bottle Griff has looks like it's the same fitting as mine, a butane 20mm clip-on but not the same as the more up to date versions, most now use 21mm clip-on fitting for anything other than the 4.5kg bottles.
Posted
https://www.gasit.co.uk//butane-20mm-28mbar-x-8mm-nozzle-1.3-kg/hr.html
    try again
