Canopy frame
the frames dont look that bad (right bend) if you take the canvass off you could tie a piece of string from the screens then round the hoops and aft, this will give you an idea of headroom and how the frames could sit if you can reuse/ alter them...
Clive,
The rear stainless frame has been replaced in the past, however the front frames are Aluminium and the port side of the frame has snapped. The break is at a previous repair where someone has pop riveted a short section of thin pipe. Also the pivots for the frame were bodged and the frame did not fully fold flat, so in the past it has been forced and bent the tubing, straightened, bent again and so on.
There are also cracks in other places, so rather than re-shape the frame I think I will replace with new stainless.
Ian :Stinky
