YorkshireAdventurer Posted May 23, 2015 Share Posted May 23, 2015 I was going to do a live stream via ustream while on the broads last however when I set up the camera all I got on the screen was bright white when I brought it inside it worked fine. Can anyone suggest any suitable camera I can that would be suitable for outside (not too expensive) Thanks Quote Link to comment Share on other sites More sharing options...
Gracie Posted May 24, 2015 Share Posted May 24, 2015 I thought I would bump this up as you haven't had a reply (I don't like it when people don't get replies). I can't help with your question, the only thing I know about cameras is they take photos lol, I know there are some very techy types on here who can probably help, so come on geeks where are you? Grace 1 Quote Link to comment Share on other sites More sharing options...
riyadhcrew Posted May 24, 2015 Share Posted May 24, 2015 Robin (London Rascal) would be my choice for that kind of advice. 1 Quote Link to comment Share on other sites More sharing options...
YorkshireAdventurer Posted May 24, 2015 Author Share Posted May 24, 2015 Where's the geeks when you need them lol 1 Quote Link to comment Share on other sites More sharing options...
deebee29 Posted May 24, 2015 Share Posted May 24, 2015 Hi Dave Sounds like a white balance issue to me Sometimes the auto settings can over compensate and burn things out I often use a cloudy setting instead of auto, could save you buying a new camera Hope this helps 1 Quote Link to comment Share on other sites More sharing options...
YorkshireAdventurer Posted May 24, 2015 Author Share Posted May 24, 2015 unfortunately the webcam doesn't seem to have settings for white balance Quote Link to comment Share on other sites More sharing options...
deebee29 Posted May 24, 2015 Share Posted May 24, 2015 Thats a shame, it can make a massive difference Sorry don't know what else to suggest. Hopefully Robin will see this, he's the expert on all things webcam I think Good luck Quote Link to comment Share on other sites More sharing options...
YorkshireAdventurer Posted May 24, 2015 Author Share Posted May 24, 2015 thanks anyway 1 Quote Link to comment Share on other sites More sharing options...
Timbo Posted May 24, 2015 Share Posted May 24, 2015 yes it is a white balance issue. Try this little trick before buying a new camera. From a cornflake packet cut out a cardboard hood you can fit in from of the camera. Use Blutack to fix it on until you get the desired length poking out in front of the camera. Long enough to cure the white out but not so long that the hood is in camera shot. Once you have the desired length for the cardboard hood and its in the right position use some electrical tape to fix it more firmly in place. Works a treat on the webcams I bought as security cameras for the back yard and works on the video camera too when I use it as a webcam and for shooting video. 2 Quote Link to comment Share on other sites More sharing options...
LondonRascal Posted May 24, 2015 Share Posted May 24, 2015 It sounds like an exposure issue to me – hence inside it is ok but the super bright outside it is not auto exposing and stuck on a level best suited for inside. Can you try getting into the exposure settings, auto /manual? From home try pointing it to the window and if you can repeat the experiences on the boat then go from there to remedy things. I suspect your not have any actual software with the camera itself but you should be able to get into the settings – try downloading manycam (google it, it is a free/paid for effects software) but the free version will let you get into the settings through manycam to then be able to fiddle with things. Failing that I use Microsoft Lifecam Cinema HD http://www.amazon.co.uk/dp/B002I3IRY8which i then wrap in copious amounts if electrical tape leaving only the lens exposed – and in the past have survived the harshest of conditions take the rain on the Queens Diamond Jubilee on the Thames, all was broadcast from Broad Ambition using them. I gave up doing the live streams because the setting up, cables, multi camera approach I took data costs and so on all was far too much stress and sometimes half way through would all fall apart when for some unknown reason the laptop decided a USB port would not recognise the camera and bring the whole shooting match down. You can see recorded streams from the past still over at www.norfolkbroadslive.com Quote Link to comment Share on other sites More sharing options...
Siddy Posted May 24, 2015 Share Posted May 24, 2015 Robin what's the data usage uploading to usteam and what quality picture you using? Quote Link to comment Share on other sites More sharing options...
LondonRascal Posted May 24, 2015 Share Posted May 24, 2015 I can't remember but it would suck thru £15.00 (3Gb)of credit easily if i was doing a few hours of streaming with good qauilty video and audio. I think I needed about 3 top ups worth of data when went to Bramerton over Breydon on distant horizon i stick to Blogging now. Quote Link to comment Share on other sites More sharing options...
YorkshireAdventurer Posted May 24, 2015 Author Share Posted May 24, 2015 thanks for your help guys much appreciated Quote Link to comment Share on other sites More sharing options...
YorkshireAdventurer Posted May 25, 2015 Author Share Posted May 25, 2015 i was actually running it through manycam didn't realise you could access the settings from there i was only using a cheapish webcam which wasn't hd so shouldn't use a huge amount of data Quote Link to comment Share on other sites More sharing options...
CaptinDread Posted May 27, 2015 Share Posted May 27, 2015 Still, you should be able to tweek the settings for the web cam on the actual computer you use in the control panel. Quote Link to comment Share on other sites More sharing options...
YorkshireAdventurer Posted May 27, 2015 Author Share Posted May 27, 2015 i can tweek the settings using manycam Quote Link to comment Share on other sites More sharing options...
