C.Ricko Posted January 18, 2018 Author Share Posted January 18, 2018 there has been a few bits done on this but as usual I commit to other peoples boats and mine take a back seat, the bearers are all in and most of the bilges painted out, I have removed 2 bulkheads/seat backs and stripped back and varnished them, just one more to do, there is an engine in and the whole thing has been looked at a lot. this is the rear seat back, the four boards on the port side are badly rotted at the base but I decided to cut them short, harden the hell out of them and put them back as I think the 90 year old wood looks better than with a few new bits or a whole new back but thats my personal taste, besides, there is a seat base going on and cushions so you won't see any of it either, in the same way I have polished and reused the original screws where possible as I think they look better, i only had enough to do the hatch in the middle but you won't see the new screws in the other bits.. 7 1 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted January 18, 2018 Author Share Posted January 18, 2018 the photos are not great but hey ho... this is the seat back from the cockpit, I don't think I have a 'before ' picture but the hatch in the pic is from the aft bulkhead of the engine bay, it was the same bubbly gluey varnish which clogged untold amounts of sanding discs... 9 1 Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted January 19, 2018 Share Posted January 19, 2018 All you guys who commit to these elderly woodies have my undying gratitude (and envy of your skills) that you will restore such lovely craft to their former glory. I salute you! 2 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted January 19, 2018 Author Share Posted January 19, 2018 couple more pictures, engine on new bearer and connected to the shaft, I made some beds to raise the engine a bit but not a difficult thing, the transom was removed and we found a bit of rot in the oak corners so one was replaced and the whole lot tightened up.. I did have a piece of wood for the transom but am just trying to find a better bit before I get it fitted.. 9 1 Quote Link to comment Share on other sites More sharing options...
JohnK Posted January 20, 2018 Share Posted January 20, 2018 I made some beds to raise the engine a bit but not a difficult thing, Probably a stupid question but why did you want to raise the engine?Thanks for creating and updating this thread. It’s fascinating to see. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted January 20, 2018 Author Share Posted January 20, 2018 Hi John, not that stupid, its because the shaft line on the new engine is lower because the engine feet, luckily the standard engine feet are the same width. there is some up and down adjustment on the isolators but not enough and I don't like to have them fully adjusted, I just put a strip of wood on top, i made it look a bit fancy and it also covered a few holes from previous installations 6 1 Quote Link to comment Share on other sites More sharing options...
Chelsea14Ian Posted January 20, 2018 Share Posted January 20, 2018 She's starting to look good,great to see classic boats coming back to life.Well done Clive. Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted January 20, 2018 Author Share Posted January 20, 2018 she looked better before we started! Strangely the areas around the screws look darker in the pictures than in reality.. you can lift these dark areas out with acid but i didn't think we needed to, Quote Link to comment Share on other sites More sharing options...
JohnK Posted January 20, 2018 Share Posted January 20, 2018 Hi John, not that stupid, its because the shaft line on the new engine is lower because the engine feet, luckily the standard engine feet are the same width. there is some up and down adjustment on the isolators but not enough and I don't like to have them fully adjusted, I just put a strip of wood on top, i made it look a bit fancy and it also covered a few holes from previous installationsAh, that makes perfect sense thank you. I was thinking centre of gravity higher, bigger angle on prop etc etc. Over thinking it as usual Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Springsong Posted January 20, 2018 Share Posted January 20, 2018 We used quite a bit of Oxalic acid on SP with amazing results. 1 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted January 20, 2018 Author Share Posted January 20, 2018 5 hours ago, springsong said: We used quite a bit of Oxalic acid on SP with amazing results. yes, it is good stuff, i finished a coat rack the other week made from a vintage water ski, it took most of the black out.. the pegs are off a telegraph pole. 5 1 Quote Link to comment Share on other sites More sharing options...
