Ray Posted June 10, 2022 Share Posted June 10, 2022 On removing a solar panel I found that sometime in the past our boat suffered an electrical fault. The junction box on the panel had melted completely and was burnt causing some burn damage to the grp. This is inside and right on top and in the middle of the area between the helm and windscreen. I can cover it but if possible I would like to make it look better cosmetically. I have tried a mild cut/polish product with only a small improvement as you can see from the before and after photos. Has anyone dealt with something like this successfully? Quote Link to comment Share on other sites More sharing options...
Smoggy Posted June 10, 2022 Share Posted June 10, 2022 Oxalic acid is usually the goto stuff, if that don't work its grind and gelcoat. 1 1 Quote Link to comment Share on other sites More sharing options...
Mouldy Posted June 10, 2022 Share Posted June 10, 2022 You need to leave it alone, Ray!! You keep finding more problems! 2 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 10, 2022 Author Share Posted June 10, 2022 26 minutes ago, Mouldy said: You need to leave it alone, Ray!! You keep finding more problems! You're not wrong Malcolm 😂 It's OK though, I've finished all the jobs!!!!! 🙄😁 1 Quote Link to comment Share on other sites More sharing options...
Mouldy Posted June 10, 2022 Share Posted June 10, 2022 2 minutes ago, Ray said: You're not wrong Malcolm 😂 It's OK though, I've finished all the jobs!!!!! 🙄😁 Yeah, right!! I thought that, but more and more little jobs seem to occur to me. My problem is that, having tried and failed to do things in the past, I find it cheaper not to try and get someone with the right skill set to do it in the first place! 😉 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 10, 2022 Author Share Posted June 10, 2022 17 minutes ago, Mouldy said: Yeah, right!! I thought that, but more and more little jobs seem to occur to me. My problem is that, having tried and failed to do things in the past, I find it cheaper not to try and get someone with the right skill set to do it in the first place! 😉 I know exactly what you mean lol But I have had some successes.. sadly these only encourage me 😁 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted June 10, 2022 Share Posted June 10, 2022 53 minutes ago, Ray said: It's OK though, I've finished all the jobs!!!!! 🙄😁 Wash your mouth out young man! Boaters don't use the F word! 1 6 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted June 11, 2022 Share Posted June 11, 2022 I've finished all the jobs!!!!! Yeah - Right. Best laugh I've had all week Griff 1 Quote Link to comment Share on other sites More sharing options...
KevinB Posted June 11, 2022 Share Posted June 11, 2022 On 10/06/2022 at 16:07, Ray said: On removing a solar panel I found that sometime in the past our boat suffered an electrical fault. The junction box on the panel had melted completely and was burnt causing some burn damage to the grp. This is inside and right on top and in the middle of the area between the helm and windscreen. I can cover it but if possible I would like to make it look better cosmetically. I have tried a mild cut/polish product with only a small improvement as you can see from the before and after photos. Has anyone dealt with something like this successfully? Have you tried Y10 gel? It might not work on a burn if it’s too deep into the gel but worth a try, it’s great stuff for removing rust marks and waterline staining , I use it a lot on my boat 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 11, 2022 Author Share Posted June 11, 2022 14 minutes ago, KevinB said: Have you tried Y10 gel? It might not work on a burn if it’s too deep into the gel but worth a try, it’s great stuff for removing rust marks and waterline staining , I use it a lot on my boat That looks good, I haven't come across that before. I'll give it a try.... Thank you 👍 1 Quote Link to comment Share on other sites More sharing options...
KevinB Posted June 11, 2022 Share Posted June 11, 2022 10 minutes ago, Ray said: That looks good, I haven't come across that before. I'll give it a try.... Thank you 👍 No probs, hope it works for you 😎 Amazing how it takes off heavy rust marks, sometimes needs 2 or 3 applications but it’s good stuff 1 Quote Link to comment Share on other sites More sharing options...
