unclemike Posted August 28, 2022 Share Posted August 28, 2022 woud like to create a cd of favourite tracks (mostly found on youtube) what format do i need to burn downloaded tracks onto a cd? Quote Link to comment Share on other sites More sharing options...
FairTmiddlin Posted August 28, 2022 Share Posted August 28, 2022 I usually down load and burn as mp3's Smaller files and better quality Quote Link to comment Share on other sites More sharing options...
RS2021 Posted August 28, 2022 Share Posted August 28, 2022 Most 'burning' software will do the format you choose. As FtM says MP3 are generally good, but choose the highest bit rate you can. Many MP3s sample at 192kbps which can sound flat on decent playback equipment these days. Go 300+ if you can. After all memory is now cheap. But, if you intend to play back on a CD player then simply select CD format on your 'burning' software. Quote Link to comment Share on other sites More sharing options...
unclemike Posted August 28, 2022 Author Share Posted August 28, 2022 thought that was the answer but just needed reassurance, its to play on the car cd autochanger Quote Link to comment Share on other sites More sharing options...
unclemike Posted August 28, 2022 Author Share Posted August 28, 2022 just need a good downoader/converter Quote Link to comment Share on other sites More sharing options...
Bikertov Posted August 28, 2022 Share Posted August 28, 2022 31 minutes ago, unclemike said: just need a good downoader/converter If the tracks are on YouTube, you will be slightly limited on quality and formats by the original format you are copying from. You can't up-convert to a higher bit rate than the original, it won't make it any better. If you are ripping from a CD, I think Windows may be able to do that natively now, without extra software ? I always used to use things like VLC, but there are so many options these days - both apps and online - for ripping and converting, best to get some recommendations from a youngster ... Quote Link to comment Share on other sites More sharing options...
DAVIDH Posted August 28, 2022 Share Posted August 28, 2022 I use this program which is very easy.https://www.4kdownload.com/products/youtubetomp3/35 You just copy the url of the track displayed on Youtube, then paste it into the program. It downloads and converts to mp3 (if necessary) in one operation. I think it allows 15 downloads per day free of charge - more and you have to pay to upgrade. Then go to your download folder, open whatever burner you're using (Windows has it's own called Windows Media Player). It comes with Windows 10 (and probably 11?) and select your tracks. Just wondering if your car player accepts USB memory sticks. That would be easier still. Just transfer to the stick, plug it in and off you go! Quote Link to comment Share on other sites More sharing options...
unclemike Posted August 28, 2022 Author Share Posted August 28, 2022 2 minutes ago, DAVIDH said: Just wondering if your car player accepts USB memory sticks. That would be easier still. Just transfer to the stick, plug it in and off you go! i wish, its 18 yr old 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted August 28, 2022 Share Posted August 28, 2022 You may need to use cda format for an 18year old player, it may not be able to read mp3. 2 Quote Link to comment Share on other sites More sharing options...
Meantime Posted August 30, 2022 Share Posted August 30, 2022 Off course you will only be making a backup copy for your own use of tracks which you already have purchased. Quote Link to comment Share on other sites More sharing options...
