wooster Posted April 23 Share Posted April 23 things? I'm looking for a place to attach a home - made emergency rope ladder. My plan was to stick a wire across two fender eyelets and hang the ladder from that. Otherwise I could attach the ladder to one eyelet only. Is this a recipe for success or otherwise? The eyelets seem strong but maybe not enough. In general is this a bad idea? Maybe this is an impossible question to answer and I should stick it onto a mooring cleat which, though it would make ladder access inconvenenient should be strong enough. I do have rails along the boat which seem strong too. I'm not sure how to tell Quote Link to comment Share on other sites More sharing options...
Regulo Posted April 23 Share Posted April 23 No. You need something bolted right through the fibreglass, with a backing pad. That's what I'd do, if I were me. 3 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 23 Share Posted April 23 I would use the cleat, and before using it check it is really secure to the boat. I have seen fender eyes ripped out of boats just by brushing fenders too hard. the last thing you would want is to get halfway up the ladder and then have the thing it was secured to break loose. 2 1 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted April 23 Share Posted April 23 As others have stated do NOT rely on a single or two fender hook fixings to support a wringing wet persons weight , you need ideally a through hull fixing with a sturdy mounting plate behind . 2 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted April 23 Share Posted April 23 Ditto wot the last three forumites said Griff 2 1 Quote Link to comment Share on other sites More sharing options...
wooster Posted April 23 Author Share Posted April 23 Thanks for the unequivocal replies. Probably a bit of a numpty question. it's more or less what I assumed but thought I'd make sure. I suppose I was hoping to get away with a bit less work being done but good to get that notion out of my head Quote Link to comment Share on other sites More sharing options...
Regulo Posted April 23 Share Posted April 23 Better to ask the question than end up with an unsafe safety device! As Grendel said, I too have seen fender eyes ripped off in minor brushes. Not to say yours aren't bolted through, but it's highly unlikely. 1 Quote Link to comment Share on other sites More sharing options...
