ranworthbreeze Posted April 29, 2022 Share Posted April 29, 2022 Mutford Lock Bridge is currently unable to open. Contact OBYS on 01502 574946 for more information Quote Link to comment Share on other sites More sharing options...
grendel Posted April 29, 2022 Share Posted April 29, 2022 ooh that might mess up Griffs return to the wet shed if they dont get it fixed soon, though he might squeeze under the bridge if the lock is still operational. Quote Link to comment Share on other sites More sharing options...
Mouldy Posted April 29, 2022 Share Posted April 29, 2022 25 minutes ago, grendel said: ooh that might mess up Griffs return to the wet shed if they dont get it fixed soon, though he might squeeze under the bridge if the lock is still operational. According to info posted on FB, it will remain unable to open over the Bank Holiday weekend, although the lock is working as normal. Im guessing that a few peoples plans may be affected for the long weekend. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted April 30, 2022 Share Posted April 30, 2022 18 hours ago, grendel said: ooh that might mess up Griffs return to the wet shed if they dont get it fixed soon, though he might squeeze under the bridge if the lock is still operational. WX charts look benign later in week for a short sea passage to Yarmouth if she won't fit under. Quote Link to comment Share on other sites More sharing options...
JanetAnne Posted April 30, 2022 Share Posted April 30, 2022 Griff will get under no problem at the right tide. The road bridge has developed a hydraulic issue which is not allowing it to close normally after being raised. Because it may need to be in the raised position for extended periods for the work to be carried out, that work will be done overnight after the holiday weekend. In the meantime the lock is, I believe, operating normally for those that fit under the road bridge. 1 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted May 5, 2022 Author Share Posted May 5, 2022 The bridge is now operable. Quote Link to comment Share on other sites More sharing options...
