oceandawn Posted October 9 Share Posted October 9 Hi Would anybody know what would cause a major power surge which short circuited the starter system resulting in a burnt out motor, frizzled cables and a melted isolater switch. The boat was not in used at the time but in a boatyard.We are at a loss. We managed to obtain a starter motor from a company in Plymouth. Excellent service next day free delivery. Worth knowing in the future for motors and alternators.Thank you in advance . Quote Link to comment Share on other sites More sharing options...
Turnoar Posted October 9 Share Posted October 9 Struck by lightning? Quote Link to comment Share on other sites More sharing options...
Turnoar Posted October 9 Share Posted October 9 I almost set a yacht on fire once trying to start the engine. I gave up after a while and with a bit of smoke having been generated, which I’d wrongly assumed but an exhaust leak or drawn back in to the engine bay, an emerging electrical smell gave a clue and the smoke built so having taken the gas bottle off the vessel and someone letting an extinguisher off all was safe again. Investigation found a nail in lieu of a fuse but could a wrongly rated fuse cause this much damage in your case? Quote Link to comment Share on other sites More sharing options...
grendel Posted October 9 Share Posted October 9 Now I could see a burned out starter motor shorting the system and frazzling the wiring, but not the other way around Quote Link to comment Share on other sites More sharing options...
oceandawn Posted October 9 Author Share Posted October 9 Hi The key apparently got stuck and wouldn't turn but worked ok when the other wiring bits were sorted so don't think it was the switch.Wrong key perhaps.Really bemused. Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted October 9 Share Posted October 9 I've known them to stick engaged and they are then turned by the engine once started creating a dynamo, alternator effect. That fries wires big time. Kindest Regards Marge and Parge Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted October 9 Share Posted October 9 7 minutes ago, MargeandParge said: I've known them to stick engaged and they are then turned by the engine once started creating a dynamo, alternator effect. That fries wires big time. Kindest Regards Marge and Parge I believe this is what happened to the boat at Loddon. Quote Link to comment Share on other sites More sharing options...
oceandawn Posted October 9 Author Share Posted October 9 That is our concern not knowing.Our feeling was that the key had jammed or the wrong key used.Either way worrying to leave it. The whole boat was professionally rewired four years ago so the wiring is good. Happy Days.Many Thanks for the replies Quote Link to comment Share on other sites More sharing options...
Smoggy Posted October 9 Share Posted October 9 2 hours ago, grendel said: Now I could see a burned out starter motor shorting the system and frazzling the wiring, but not the other way around Like wot he said, a short anywhere other than the starter motor would just cook the wiring, why would the key be in use if the boat was not in use? I know on my volvo's if the key is in the engine stop position instead off the fully off position the fuel solenoid is powered up but not linked to starter circuit and only likely to flatten battery or burn out fuel solenoid. Always good to turn battery isolators off when leaving boat for any length of time, I always do between visits as well as seacocks and gas. 1 Quote Link to comment Share on other sites More sharing options...
oceandawn Posted October 9 Author Share Posted October 9 The boat was having work done in a yard so presumably moved around.It wasn't until it was being returned that one engine wouldn't work and the key wouldn't engage.We assumed that is was just the motor until further investigation revealed the extent.We were not with it so it is difficult ascertain how it all happened. Quote Link to comment Share on other sites More sharing options...
annv Posted October 9 Share Posted October 9 Hi Ocean Dawn What can happen with inert a starters is pinion jams on flywheel ring gear then if key turned to start will fry the starter which then overheats solenoid causing it to stick/weld its contacts closed creating a dead short. If a prengage starter its either the solenoid or the key that gets stuck turning it into a motor which if left running will burn out the starter motor as they are only designed to run for short time ie engine starting,They can also stick on the armature shaft then when engine starts will be powered by the ring gear which then burns/shorts the windings in the motor turning it into to a dynamo if this happens you only get a humming sound from the motor spinning, easy to hear on a car but sound proofed on a boat, Hard to start engines also cause overheating of starters. John 3 Quote Link to comment Share on other sites More sharing options...
