DaveT Posted October 3, 2017 Share Posted October 3, 2017 I need to replace the U groove nylon sliding window roller bearings on my Bounty 34CC. I can find lots of almost similar examples on line but they come in lots of 100! Is there a local supplier /repairer who might have these or could advise me where to look or have any owners with similar types of sliding windows been able to source them. As far as I can see the bearings are 8. 32. 10. mm but suspect they may be imperial measurements. I am not sure if the bolts are integral to the bearing as I could not remove them without destroying the original and can't do that without replacements to hand. Regards, DaveT Quote Link to comment Share on other sites More sharing options...
Vaughan Posted October 3, 2017 Share Posted October 3, 2017 I know the ones you mean. I think we got them from Seaglaze, or Trend Aluminium in Norfolk, But it may have been Peachments, as they are next door to the old Bounty Boats. Have a look at the rails as well as they can get worn and may get rather sharp edges. 1 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted October 3, 2017 Share Posted October 3, 2017 Just had a thought. Have a look at the bottom corners of the glass in the canopy windows and windscreen. It is normally marked by the maker of the windows and that would tell you who supplied the rollers. 1 Quote Link to comment Share on other sites More sharing options...
WherryNice Posted October 3, 2017 Share Posted October 3, 2017 Hi DaveT, sorry I cant be any help with the bearings but your boat wouldnt happen to be Z69 by any chance would it?Sent from the Norfolk Broads Network mobile app 1 Quote Link to comment Share on other sites More sharing options...
Bound2Please Posted October 3, 2017 Share Posted October 3, 2017 8x28x9 Is the nearest in steel bearings, cant say on nylon as I only stock metal ones. But no nylon ones show up on bearing net. Are they bearings or nylon bushes? Charlie 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 3, 2017 Author Share Posted October 3, 2017 (edited) No luck with the 3 options today, none of the companies stock these bearings, hope someone will be able to come up with a solution, there seems to be lots of boats with sliding access windows/doors and all must use bearings of some sort.The bolts holding the bearings to the frame are quite substantial but I forgot to measure them and live a long way from the boat's winter mooring but you can see the proportion clearly in the 3rd image Many thanks to those who have responded earlier. Edited October 3, 2017 by DaveT 1 Quote Link to comment Share on other sites More sharing options...
Daddy Mouse Posted October 3, 2017 Share Posted October 3, 2017 Have you tried searching for nylon bar. It's easy to drill and cut to length.If you only need a few it would not take long to make them.Another alternative is to find someone with a 3D printer they would make them for pence in material costSent from the Norfolk Broads Network mobile app 1 Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted October 3, 2017 Share Posted October 3, 2017 Just now, Daddy Mouse said: Have you tried searching for nylon bar. It's easy to drill and cut to length. If you only need a few it would not take long to make them. Another alternative is to find someone with a 3D printer they would make them for pence in material cost Sent from the Norfolk Broads Network mobile app Oh who do we know with a 3D printer 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted October 3, 2017 Share Posted October 3, 2017 OOh I think I might know someone, a lot depends on the load they will need to take, if they are just guides, then they should be fine 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 3, 2017 Author Share Posted October 3, 2017 Hi Grendel Many thanks for your reply I presume they are guides but they do take the load of the window both in the closed and open positions, it's not particularly heavy but being an angled L (about 110 degree ) shape, is a bit mauling to carry. They would need to be U shaped profile as you can see on the original post, there are 4 in total, 2 at the top corner and 2 at the bottom. This is a picture of the window open, you can see the 4 nuts on the outside if you can expand the image, any bolts holding the bearings in place would need to be flush or thereabouts as per the originals, countersunk probably as there is little clearance behind. I could not remove the originals without completely destroying what was left of the steel bearings, the other 3 are in much worse state Am very interested in your suggestion Regards Dave Quote Link to comment Share on other sites More sharing options...
grendel Posted October 3, 2017 Share Posted October 3, 2017 looking at them, it would appear that if you undo the nut and take the whole thing off, the nylon bit would just slide off the nut end. looks like the inside should look something like this - http://www.vxb.com/Round-Nylon-Pulley-U-Groove-Track-Bearing-BU0832-p/8x32-ugroove-pulley-bearing.htm these are a bit bigger diameter - http://www.ebay.co.uk/itm/8-50-12mm-Pulley-Plastic-Rope-Wheel-Round-Sealed-Accessories-Nylon-Guide-Rail-/311899805255 these dont have the groove http://www.ebay.co.uk/itm/Bathroom-Nylon-Pulley-Shield-Ball-Bearings-Wheel-Roller-Choose-Size-/361864522663 though these may be spot on - http://www.ebay.co.uk/itm/U-V-Grooved-Ball-Bearings-Metal-Shield-Nylon-Pulley-Wheels-Wire-Guide-Roller-/361777816322 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted October 3, 2017 Share Posted October 3, 2017 these have the bolt. https://www.ebay.co.uk/i/362055875007?chn=ps&dispItem=1&adgroupid=43106429403&rlsatarget=pla-325869832768&abcId=1128926&adtype=pla&merchantid=10075494&poi=&googleloc=1006602&device=c&campaignid=857233083&crdt=0 this has a 10mm hole. http://www.ebay.co.uk/itm/35mmx10mmx11mm-Nylon-U-Groove-Bearing-Pulley-Sliding-Converyor-Wheel-White/302422937856?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3D7a00de3357ba43d592f68a8f2cc7c295%26pid%3D100677%26rk%3D4%26rkt%3D12%26sd%3D362055875007&_trksid=p2385738.c100677.m4598 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted October 3, 2017 Share Posted October 3, 2017 they do them with v grooves as well - http://www.ebay.co.uk/itm/Precision-Acetal-Pulley-Wheel-with-90-V-groove-Guiding-Rail-Sliding-Mechanism-/171950297737 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 3, 2017 Author Share Posted October 3, 2017 Hi Grendel Am sure that these are exactly what I need, will be ordering them ASAP, Many thanks for your time and help Regards DaveT Quote Link to comment Share on other sites More sharing options...
grendel Posted October 3, 2017 Share Posted October 3, 2017 with care dissasembling you should be able to re- use the bolt part with one of the above bearings, I would imagine the bolt part could be tapped through the bearings in the wheel and then cleaned up and put into the new bearing roller. Quote Link to comment Share on other sites More sharing options...
andy Posted October 3, 2017 Share Posted October 3, 2017 Not good of Trend as they were the ones that made it Quote Link to comment Share on other sites More sharing options...
Vaughan Posted October 4, 2017 Share Posted October 4, 2017 8 hours ago, andy said: Not good of Trend as they were the ones that made it I thought so! A good bit of after sales service would have been to say where they sourced the bearings from. They must have records. Quote Link to comment Share on other sites More sharing options...
Vaughan Posted October 4, 2017 Share Posted October 4, 2017 12 hours ago, grendel said: with care dissasembling you should be able to re- use the bolt part with one of the above bearings, I would imagine the bolt part could be tapped through the bearings in the wheel and then cleaned up and put into the new bearing roller. Perhaps I ought to mention that the threaded fixing bolt is offset from the centre of the roller, forming an eccentric, so that the pulley can be turned to the best position for height and then tightened up with the locknut. This is important if the door is to slide freely on its runners. Quote Link to comment Share on other sites More sharing options...
Paul Posted October 4, 2017 Share Posted October 4, 2017 these any good? http://www.ebay.co.uk/itm/U-Shape-Deep-Groove-Idler-Pulley-Ball-Bearing-Nylon-Plastic-Embedded-Series-/262631176659 1 Quote Link to comment Share on other sites More sharing options...
Paul Posted October 4, 2017 Share Posted October 4, 2017 lots of options in 8*30*10, standard, shallow and deep groove, but 32 is a non standard size 1 Quote Link to comment Share on other sites More sharing options...
