grendel Posted August 20, 2020 Author Share Posted August 20, 2020 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted August 20, 2020 Author Share Posted August 20, 2020 Past the limit of navigation for hire craft 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted August 20, 2020 Author Share Posted August 20, 2020 3 Quote Link to comment Share on other sites More sharing options...
Guest Posted August 20, 2020 Share Posted August 20, 2020 I am next but one to Water Rail this evening at Beccles, nice looking boat. Quote Link to comment Share on other sites More sharing options...
YnysMon Posted August 20, 2020 Share Posted August 20, 2020 5 hours ago, grendel said: Past the limit of navigation for hire craft Thanks for posting Peter. We are hoping to make it past Bishop’s Bridge next week, so it’s super helpful to have a ‘preview’. Quote Link to comment Share on other sites More sharing options...
grendel Posted August 21, 2020 Author Share Posted August 21, 2020 Helen when you get up to the mill pond keep to the left and turn near the races, the ranger told me there is a shallow gravel bank just in front of the steps, then return keeping to that same side, for the rest of the trip, keep near the centre as you can see the weeds under the surface near the edges. Quote Link to comment Share on other sites More sharing options...
YnysMon Posted August 21, 2020 Share Posted August 21, 2020 Thanks very much for the advice Peter. Quote Link to comment Share on other sites More sharing options...
LizG Posted August 21, 2020 Share Posted August 21, 2020 You also need to careful lining up for Bishop's Bridge on the return as the last time I did it there were fishermen near it. Just take it nice and slow and enjoy the experience. Aim to be doing it near high tide. If there has been a lot of rain, there might a bit of a current at New Mills so make sure she behaves turning as the sides are brick!!!Sent from the Norfolk Broads Network mobile app 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted August 21, 2020 Author Share Posted August 21, 2020 she only doesnt respond when turning starboard because the rudder goes too far across and ends up at right angles to the boat at full lock, back it off and you should be ok (this is what happens when someone with an engineering background is let loose on a boat for a week, things get looked at and evaluated) 1 Quote Link to comment Share on other sites More sharing options...
YnysMon Posted August 21, 2020 Share Posted August 21, 2020 Thanks the for extra tips Liz, and for the tip about the rudder Peter. I noticed that it was much easier turning one way than the other. Quote Link to comment Share on other sites More sharing options...
grendel Posted August 21, 2020 Author Share Posted August 21, 2020 there are 2 turns to starboard and one to port from the centre position, if you restrict yourself to a single turn of the wheel to starboard, it should be pretty even each way. 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted August 21, 2020 Author Share Posted August 21, 2020 I oiled the steering pulleys which seemed to make things a bit easier, but under way you have the pressure of the water against the rudder. she does steer in reverse, but use small movements of the wheel and plan ahead, you need enough way to get flow over the rudder to steer, tickover is enough to achieve steerable reverse (about 1 mph). as long as you are not trying to perform a sharp turn, the steering is enough to reverse along the river, I went all the way into the dyke at the locks from the pond area outside in reverse and managed to get her alongside. 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted August 21, 2020 Author Share Posted August 21, 2020 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted August 21, 2020 Author Share Posted August 21, 2020 And thats it, folks, All my August holiday videos uploaded to youtube 2 Quote Link to comment Share on other sites More sharing options...
SwanR Posted August 21, 2020 Share Posted August 21, 2020 Loved the one of all the chaos at How Hill. Thanks for sharing them. Quote Link to comment Share on other sites More sharing options...
grendel Posted August 21, 2020 Author Share Posted August 21, 2020 they are nothing special, no commentary, just taken as I was cruising along, I have tried to video some of the less travelled places, above low bridges, or like the trip to new Mills, areas where hire boats cannot go, so that others can get a feel for the wonders of the broads that are out there. I am lucky, the camera breaks videos into 18 minute (approx) sections. some videos are in more than one playlist (some as many as 4 playlists) but the idea is if someone wants to view a particular section of river, then its there as a playlist, I think i may still have some from July still to load, but I will get to those as and when Quote Link to comment Share on other sites More sharing options...
