Ray Posted July 18, 2021 Share Posted July 18, 2021 The frustration of trying to buy a small, cheap, simple item when you can't search because you can't for the life of you think what it's called lol It's a terminal that you can crimp on to the end of a cable, not a spade, it looks like a washer with the crimpable part attached. They are generally put over a post (like a car battery) and then a nut is screwed down the post on top of it for a secure connection. What the dickens do I search for in google please? I actually need them for the earth wire in a 240v shore power cable. Quote Link to comment Share on other sites More sharing options...
CeePee1952 Posted July 18, 2021 Share Posted July 18, 2021 3 minutes ago, Ray said: The frustration of trying to buy a small, cheap, simple item when you can't search because you can't for the life of you think what it's called lol It's a terminal that you can crimp on to the end of a cable, not a spade, it looks like a washer with the crimpable part attached. They are generally put over a post (like a car battery) and then a nut is screwed down the post on top of it for a secure connection. What the dickens do I search for in google please? I actually need them for the earth wire in a 240v shore power cable. round crimp connectors (I think!) Chris 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted July 18, 2021 Author Share Posted July 18, 2021 I'll try it! π Quote Link to comment Share on other sites More sharing options...
Ray Posted July 18, 2021 Author Share Posted July 18, 2021 Got them! Many thanks!Β 1 Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted July 18, 2021 Share Posted July 18, 2021 https://www.amazon.co.uk/gp/slredirect/picassoRedirect.html/ref=pa_sp_mtf_aps_sr_pg1_1?ie=UTF8&adId=A00594831Y6WNY0D97IL7&url=%2FXinzistar-Battery-Terminals-Release-Connector%2Fdp%2FB08L6FRN5Z%2Fref%3Dsr_1_7_sspa%3Fcrid%3DH9PAM059L6N0%26dchild%3D1%26keywords%3Dbattery%2Bconnectors%2Bquick%2Brelease%26qid%3D1626636028%26sprefix%3Dbattery%2Bconnectors%2Caps%2C258%26sr%3D8-7-spons%26psc%3D1&qualifier=1626636028&id=4924714895641263&widgetName=sp_mtf Something like this. 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted July 18, 2021 Author Share Posted July 18, 2021 That's the sort of thing, it's just the ring part I needed π Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted July 18, 2021 Share Posted July 18, 2021 Ray, the proper HD version is Copper tube crimp lugs 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted July 19, 2021 Author Share Posted July 19, 2021 Many thanks! It's odd how many things have names I'm entirely unaware of. It does explain though why I used to spend hours in DIY superstores back in the day.... up and down every aisle looking for the widget-thingy that I needed lol 1 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted July 19, 2021 Share Posted July 19, 2021 Hello Ray if you call in a Brian Wards and see Tanya or Tim they can show you what crimp connectors they have in stock. They may even have setts of mixed crimped terminals. The colour of the plastic on the crimp dictates the current and cable size that is used on the connector, typical colours are Red, Blue, Yellow, Green. Regards Alan 1 Quote Link to comment Share on other sites More sharing options...
Bluebell Posted July 19, 2021 Share Posted July 19, 2021 Alan, Iβve not come across the green ones, do you know what they are for? Quote Link to comment Share on other sites More sharing options...
annv Posted July 19, 2021 Share Posted July 19, 2021 Hi Commonly called a bango crimp connectors they come in three colours red smallest dia cable then blue then yellow, Β there are more but these are the norm for vehicles boats etc they do have different types of insulation so are sub divided for specialist uses. John 1 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted July 19, 2021 Share Posted July 19, 2021 45 minutes ago, Bluebell said: Alan, Iβve not come across the green ones, do you know what they are for? Hello Jim, I still got a few in my crimp bit boxes my guess is that they are 3mm. The current cable sizes and colours is as follows:- Red 1mm, Black 1.5mm, Blue 2.5mm, Gray 4mm, Yellow 6mm above these sizes tends to be uninsulated crimps for heavy duty cables. Regards Alan Β Β 2 Quote Link to comment Share on other sites More sharing options...
