Advice On Towing A Tender
mikeyboy1966
Now I’ve finished off restoring “tango” I thought it would be fun to actually use it:default_biggrin:
so hopefully (weather permitting)
I’ll take it down to the RGO next weekend and the following weekend for our last two trips of the season as the big boat is being lifted onto hard standing over winter to allow me to do some maintenance and planned improvements.
any advice from more experienced crews welcomed.:default_sailing:
Hi Micky tie two ropes from front of dingy with a loop in each end and fasten/hook each one to your stern cleats this will keep the dingy  following   in the middle of your transom and as you dont stern moor it wont get in the way you will need a fender to stop dingy bumping your stern for when you slow down/stop, ideally as close to your stern as possible, a little experimenting will get you the best position. John
