Prop Shafts!
It appears likely that "Glenmore" will need a new prop shaft. An engineering company has made an attempt to straighten the existing one at no small cost I might add! But, once again, on taking up drive, there is an unholy clattering and vibration from the rear that seems to come from the rear cutlass bearing. Local "sages" are suggesting that the attempted straighten has not worked and the consequent uneven running has worn down these bearings again. Although "Glenmore" has done very limited running since this repair back in July/August 2011, the company that did the work are washing their hands of any responsibility because of the time that has elapsed. Long discussions and concerns fall on very deaf ears!
Anyway, we lifted "Glenmore" yesterday for a look and another engineer suspects either bent or misaligned prop shaft. Both outside cutlass bearings need replacing for sure so the shaft has to be pulled and will be checked for straightness. Some "sages" are suggesting that straightening a bent prop shaft is never 100% successful and that its best to "bite the bullet" or "grasp this very expensive nettle" and go for a new one. Has anyone any opinions on this?
My next question is about a new shaft. It is somewhere in the region of five feet long with a taper at one end at least. The guesstimate of the engineer as to cost of a new one sets ones heart a fluttering seriously! £450!! And that is without any associated labour.
Has anyone any experience of buying a prop shaft? Where from? How much? Who's best to supply?
Any advice at all will be very gratefully received!
Trevor
www.normanboats.co.uk
Tought a4 was 316, just another name, if you want higher quality go for a5, but a prop shaft should be ok at a4, a really though stainless is a feric one (f1) but machining it then becomes a problem, these figures relate to the tensile stress/elongation of fasteners , not a property of a prop shaft where the torque value is more relevant,the only reason to make a shaft out of stainless is to stop it rusting,a steel shaft is more than strong enough for the job...but rusts.
Some stainless steel ,is not suitable for salt water use because of it s chemical make up...hence brown staining on cheap rails and screws, 316,a4 is recommended for marine use(salt water aplications)
I had a new prop 'made to measure' and as part of this Clement checked my prop shaft tolerance. I had a full tour of the facility and can't recommend them highly enough.
http://www.clementsmarine.co.uk/propeller-shafts
See the PDF for more info
Whilst 316 series stainless steels are excellent materials for
general use, duplex alloys are now preferred. These alloys
offer much higher strength and are more cost effective than
other high performance stainless steels and more exotic
materials. Consequently, duplex stainless alloy shafts can
safely be designed with substantially reduced diameters
compared to those made of the 316 series, giving the
architect and boat constructor much greater freedom than
previously, and often providing significant weight saving
advantages.
The surprise on the prop was that the 'made to measure' prop cane in less than a Vetus 'off the peg' and the service received stunning.
