Starbrite Posted August 24, 2018 Share Posted August 24, 2018 Out on the boat near Lincoln my jabsco pump won't pull the water up to the filter I can't find the fault Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
grendel Posted August 24, 2018 Share Posted August 24, 2018 air leak in the pipe? is this for the cooling water, or drinking water. if its cooling has your impellor shredded itself? Quote Link to comment Share on other sites More sharing options...
Starbrite Posted August 24, 2018 Author Share Posted August 24, 2018 air leak in the pipe? is this for the cooling water, or drinking water. if its cooling has your impellor shredded itself?Hi it's the cooling the impeller looks good but I can see into the filter and no water coming up Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 24, 2018 Share Posted August 24, 2018 Is there a seacock or closing valve somewhere that has been closed by mistake ? Quote Link to comment Share on other sites More sharing options...
Starbrite Posted August 24, 2018 Author Share Posted August 24, 2018 Grendel was just pulled impeller out and all back of the blades are damagedSent from the Norfolk Broads Network mobile app 1 Quote Link to comment Share on other sites More sharing options...
Timbo Posted August 24, 2018 Share Posted August 24, 2018 Lincoln Chandlery at Burton Waters sell Jabsco impellors Quote Link to comment Share on other sites More sharing options...
Starbrite Posted August 24, 2018 Author Share Posted August 24, 2018 Thanks I'll try Burton waters tomorrow Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted August 24, 2018 Share Posted August 24, 2018 Make sure you try and get all the broken parts out or it could block the engine. 1 Quote Link to comment Share on other sites More sharing options...
tjg1677 Posted August 25, 2018 Share Posted August 25, 2018 And grease the new one lightly before fitting, both on the impeller blades and the drive splines. Quote Link to comment Share on other sites More sharing options...
annv Posted August 25, 2018 Share Posted August 25, 2018 Only use water pump grease or impeller grease not ordinary petroleum grease.John Quote Link to comment Share on other sites More sharing options...
StillCruising Posted August 25, 2018 Share Posted August 25, 2018 If you buy the impeller in a kit with the gaskets you get the proper grease included.. Regards Bob Quote Link to comment Share on other sites More sharing options...
Starbrite Posted August 25, 2018 Author Share Posted August 25, 2018 Bought kit from Burton waters £50 passed curtain wire though bowman cleaned it out found inlet pipe had come loose on the filter Sent from the Norfolk Broads Network mobile app 1 Quote Link to comment Share on other sites More sharing options...
Timbo Posted August 27, 2018 Share Posted August 27, 2018 On 25/08/2018 at 14:29, Starbrite said: Bought kit from Burton waters £50 passed curtain wire though bowman cleaned it out found inlet pipe had come loose on the filter Sent from the Norfolk Broads Network mobile app Give me a shout next time I'll put the kettle on! Quote Link to comment Share on other sites More sharing options...
Starbrite Posted August 27, 2018 Author Share Posted August 27, 2018 Give me a shout next time I'll put the kettle on! I'm outside woodcocks now Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
Timbo Posted August 27, 2018 Share Posted August 27, 2018 1 minute ago, Starbrite said: I'm outside woodcocks now Sent from the Norfolk Broads Network mobile app You moored there all day? Quote Link to comment Share on other sites More sharing options...
Starbrite Posted August 27, 2018 Author Share Posted August 27, 2018 You moored there all day?Till 11 then Saxilby Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
Timbo Posted August 27, 2018 Share Posted August 27, 2018 1 minute ago, Starbrite said: Till 11 then Saxilby Sent from the Norfolk Broads Network mobile app Ages since I've been to Saxilby, I may take a saunter when I've dropped the Mrs off at work. Quote Link to comment Share on other sites More sharing options...
Starbrite Posted August 27, 2018 Author Share Posted August 27, 2018 Ages since I've been to Saxilby, I may take a saunter when I've dropped the Mrs off at work.Ok Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
