Grease Is The Word
Duckhams used to produce water pump grease, which you also use on old fashioned stern glands which have a grease cap. Peachments sell a grease called Morris (I forget the number) and I am sure Brian Ward or other chandlers sell something similar.
The thrust bearing on the hydraulic motor takes any normal grease, that you would use on roller bearings.
