Water Testing?
CaptinDread
So we have 2 Broads Authority bods up here who are testing the water points for any nasties.
How they do this is to turn the tap on for half an hour and then get a sample.
surely they could get a sample now without wasting water?
what difference would running the tap for half hour have?
just seems a bit hokey to me.
Don't you have to run taps fairly regularly to stop Legionnaires Disease?
Granted 30mins seems excessive (unless paid by the hour!) and that they would be used regularly but risk assessment are risk assessments!
Unused outlets i.e. your cellar or outside taps ect on a normal building is 2mins weekly to stop Legionnaires Disease etc your only flushing a small section of pipe. But depends how long the run is back to the next used section which could be a distant on moorings. Think they should have took a test after a few mins then after the 30mins to see the readings.
I always flush the hoses to run cold before filling the tank.
It's whoever the supply belongs to so if there Ba's moorings they 'should' be responsible. We have to test our buildings weekly and put our name to it for temps tested and any flushings. It's all part of the blame game incase someone gets ill.
