Andrewcook Posted July 4, 2019 Share Posted July 4, 2019 Here's this question for you Forum Members has many Sailing Boats managed to get under Potter Heigham Bridge going to Hickling Broads and other places on that side due to it being Dredged out over the Years. As to Cruising Boats don't normally get under that Bridge due to High water at times as it stops them from getting back under into the main river Thurne. Yours Andrew Cook Quote Link to comment Share on other sites More sharing options...
grendel Posted July 4, 2019 Share Posted July 4, 2019 Andrew, most broads sailing cruisers will still fit under Potter Heigham bridge, all of Marthams sailing boats do, and I suspect all of hunters sailing boats too. as to the dredging, I believe it has been established previously that dredging above the bridge makes no difference to the access under the bridge, that is a more complex balance of tides, weather and wind direction. generally the bridge pilots will advise on whether you can get a cruiser under the bridge on that day, and whether the weather wil stop you passing back under the next day. Quote Link to comment Share on other sites More sharing options...
Ray Posted July 4, 2019 Share Posted July 4, 2019 Hi Andrew, unless I've misunderstood your question then yes many sailing boats do indeed still pass under the bridge due to being able to lower their masts. The 3 Rivers Race goes through Potter Heigham. The question of dredging seems far more complicated than first glance and I'll let someone who understands it better answer that one. Some motor cruisers can still pass under the bridge if the the tide and conditions allow but not nearly as often as in the past and indeed there is always some concern about getting back! Edit: I see Grendel has answered as I type Quote Link to comment Share on other sites More sharing options...
Poppy Posted July 4, 2019 Share Posted July 4, 2019 1 hour ago, Ray said: Hi Andrew, unless I've misunderstood your question then yes many sailing boats do indeed still pass under the bridge due to being able to lower their masts. The 3 Rivers Race goes through Potter Heigham. The question of dredging seems far more complicated than first glance and I'll let someone who understands it better answer that one. Some motor cruisers can still pass under the bridge if the the tide and conditions allow but not nearly as often as in the past and indeed there is always some concern about getting back! Edit: I see Grendel has answered as I type They were of a different design in the past . Take a look at these https://www.marthamboats.com/hire/motor-cruisers Then compare them with these https://www.marthamboats.com/hire/motor-cruisers The width of the cabin is the issue with 'arched' bridges like Potter and Wroxham. Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted July 4, 2019 Share Posted July 4, 2019 55 minutes ago, Poppy said: They were of a different design in the past . Take a look at these https://www.marthamboats.com/hire/motor-cruisers Then compare them with these https://www.marthamboats.com/hire/motor-cruisers The width of the cabin is the issue with 'arched' bridges like Potter and Wroxham. The link is the same for both, nice to see the Jocelyn back in the fleet, anyone fancy hiring it for the meet in August. Quote Link to comment Share on other sites More sharing options...
grendel Posted July 4, 2019 Share Posted July 4, 2019 I have jayne hired for that week, maybe they will upgrade me again Quote Link to comment Share on other sites More sharing options...
TheQ Posted July 5, 2019 Share Posted July 5, 2019 I've never come across a sailing boat that can sail on the main rivers, that can't get under Potter, you can always take the mast down. There will besome that can't get past the bridge not because the bridge is too low, But because the water isn't deep enough, tide permitting you can stand on the bottom under the bridge it's only about 4 ft deep. This picture fairly well shows the depth of the river, it's more shallow and a harder bottom under the bridge. Quote Link to comment Share on other sites More sharing options...
wombat nee blownup Posted July 5, 2019 Share Posted July 5, 2019 I've never come across a sailing boat that can sail on the main rivers, that can't get under Potter, you can always take the mast down. There will besome that can't get past the bridge not because the bridge is too low, But because the water isn't deep enough, tide permitting you can stand on the bottom under the bridge it's only about 4 ft deep. This picture fairly well shows the depth of the river, it's more shallow and a harder bottom under the bridge.[/Are there any descendants of the driver willing to take down the rest?Sent from the Norfolk Broads Network mobile app Quote Link to comment Share on other sites More sharing options...
