Boat Moving Company Needed
smitch6
I have a 3 ton boat 26' x 10' i need moving from a field near beccles to loddon
I used GMR to bring it here and he charged me £350 to move it from the other side of cambridge to beccles, he has since retired......
the cheapest i have found to move it from beccles to loddon it £480
I have tried Abbott transport, MRA transport, wavetrade,
All the trailer boys can't move it as they can only move 2.75ton. so i think it'll have to be hi-abed as 3 ton is pretty heavy
17 minutes ago, OldBerkshireBoy said:
Don`t know if Chillout solutions have a Hi-ab but they move boats.
They do indeed, seen them at Woods. There's Boat Shift as well but will not be a budget solution I suspect. But they are specialists in lifting and moving boats and fully insured. That's what you pay for.
Just looking again, if it's in a field that might be more of a problem. The above usually rely on a lift out at a boat yard. Probably a hi ab might be the only way assuming it can get in the field and the ground's not too soft!
