MauriceMynah Posted June 9, 2021 Share Posted June 9, 2021 Vaughan, I've told you before, you should never let a lifetimes work and experience contradict a perfectly sound theory. 1 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted June 9, 2021 Share Posted June 9, 2021 Time you got yourself a new avatar, old chap. So how's the new boat going? We are waiting for a report! Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted June 9, 2021 Share Posted June 9, 2021 I can state , it’s looking good !! Quote Link to comment Share on other sites More sharing options...
AndyTBoater Posted June 10, 2021 Author Share Posted June 10, 2021 Thanks for all your help with this. Progress will be made and i will update you as to the results I have a couple of days spare next week so will... 1. Get digital rev counter thing 2. Sort out tickover (700 RPM ish) Robin - thanks for the offer. I probably wont be over your end of the world until the wooden weekend. Will chat more and sort something out. (or I may well cancel all my work and pottle over before then. I will let you know) Quote Link to comment Share on other sites More sharing options...
AndyTBoater Posted June 18, 2021 Author Share Posted June 18, 2021 Newsflash - Newsflash - Newsflash Tickover reduced to 700 rpm - Check 17x13 prop purchased (on the recommendation of Peachment's and with advice from this forum - Check Getting the boat out and prop changed - ongoing. :( Everyone I have contacted has either said that they will call me or that I should ring back "in a week or so". Anyway. I shall report back on progress and stuff Thanks for all your help and advice. Andy 7 Quote Link to comment Share on other sites More sharing options...
AndyTBoater Posted June 23, 2021 Author Share Posted June 23, 2021 Yo Ho Ho Etc. Eric at Cox`s fitted the new prop this morning. Quick pootle down to Potter - just to make sure it wont fall off. Its blimmin transformed the boat. It now turns better and is a lot more responsive to throttle inputs (Read that as actually slowing down when going from forward to reverse in slightly less than geological time). 1000rpm is about 4MPH (give or take a tide/ wind combo) Did an easy 6mph in the bit that allows you to do 6mph and nothing vibrated off the shelves. Its a miracle Guvnor. And I can now do the How Hill run in less than 12 parsecs !!! I haven't measured the old prop yet but it looks significantly smaller than the 17x13 thats now attached. Thanks for all your advice An(dy) Solo 6 1 Quote Link to comment Share on other sites More sharing options...
AndyTBoater Posted June 28, 2021 Author Share Posted June 28, 2021 Just for info I have now measured the old prop and it seems to be (calculations done twice) a 16x10 which is a bit different to the 17x13 now attached. No wonder she was revving slightly. Anyone in need of a 16x10 x 3 blade in VGC with a 1.25" shaft? Toot Toot Andy 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted June 28, 2021 Share Posted June 28, 2021 Well done Perseverance and taking advice did the trick Griff Quote Link to comment Share on other sites More sharing options...
Guest Posted June 28, 2021 Share Posted June 28, 2021 1 hour ago, AndyTBoater said: Anyone in need of a 16x10 x 3 blade in VGC with a 1.25" shaft? Our prop hit a submerged object a few days ago and we now have a shudder/vibration under power, she's out of the water on Friday for a check!... 💰 🤑 💸 Quote Link to comment Share on other sites More sharing options...
Islander Posted June 28, 2021 Share Posted June 28, 2021 Fingers crossed for you John that it’s only something wrapped around the prop/shaft. Best regards to Eileen from us both. Colin Quote Link to comment Share on other sites More sharing options...
Maxwellian Posted June 28, 2021 Share Posted June 28, 2021 6 hours ago, Jemaki said: 7 hours ago, AndyTBoater said: Our prop hit a submerged object a few days ago and we now have a shudder/vibration under power, she's out of the water on Friday for a check!... 💰 🤑 💸 Where about did this happens? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 28, 2021 Share Posted June 28, 2021 55 minutes ago, Maxwellian said: Where about did this happens? Between Wroxham and Horning. Quote Link to comment Share on other sites More sharing options...
JanetAnne Posted June 28, 2021 Share Posted June 28, 2021 We had to lift Kingfisher out last week when she acquired a lump of best Axminster round the prop on Oulton Broad. These exceptionally low tides and shallower areas seem to be allowing all sorts of detritus to be disturbed from the river bed. Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted June 29, 2021 Share Posted June 29, 2021 14 hours ago, Maxwellian said: Where about did this happens? Close to the stern, midships, and under water. 3 Quote Link to comment Share on other sites More sharing options...
