Ray Posted June 26, 2022 Share Posted June 26, 2022 Does anyone happen to know the size of the hose that attaches to the air vent of the holding tank? Quote Link to comment Share on other sites More sharing options...
Mouldy Posted June 26, 2022 Share Posted June 26, 2022 1 hour ago, Ray said: Does anyone happen to know the size of the hose that attaches to the air vent of the holding tank? Uh-ho! Ray, this might not end well! You know what happens when you start these ‘little’ jobs!! 😉 1 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted June 26, 2022 Share Posted June 26, 2022 how big is it? ! probably 1.3/4" or 1.1/2" ID 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 26, 2022 Author Share Posted June 26, 2022 13 minutes ago, Mouldy said: Uh-ho! Ray, this might not end well! You know what happens when you start these ‘little’ jobs!! 😉 It's the only bit I haven't replaced, seems like a good idea... hopefully 😁 13 minutes ago, C.Ricko said: how big is it? ! probably 1.3/4" or 1.1/2" ID Ah, not the large waste carrying ones, the much thinner one that allows pressure to equalise in the tank itself... I was thinking about 1/2" possibly? 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2022 Share Posted June 26, 2022 4 minutes ago, Ray said: It's the only bit I haven't replaced, seems like a good idea... hopefully 😁 Ah yes, I have lots of those type of boat jobs. You know, the one's that seem like a good idea...at the time, and months later you look back and think, why the blooming hell did I start doing this Quote Link to comment Share on other sites More sharing options...
Mouldy Posted June 26, 2022 Share Posted June 26, 2022 4 minutes ago, BroadsExplorer said: Ah yes, I have lots of those type of boat jobs. You know, the one's that seem like a good idea...at the time, and months later you look back and think, why the blooming hell did I start doing this Ray may be able to compare notes with you there!! 😉😁 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 26, 2022 Author Share Posted June 26, 2022 Just now, Mouldy said: Ray may be able to compare notes with you there!! 😉😁 I consider myself something of an expert on jobs I wish I hadn't started 😁 1 Quote Link to comment Share on other sites More sharing options...
Regulo Posted June 26, 2022 Share Posted June 26, 2022 Depends on the size of the tank and skin fittings - just get one that fits! Quote Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2022 Share Posted June 26, 2022 5 minutes ago, Ray said: I consider myself something of an expert on jobs I wish I hadn't started 😁 Indeed, I specialise in the same area of expertise unfortunately I am sure however that you have a wonderful boat to be proud of and which gives you many hours of pleasure, when you finally find your way out of the bilges of course Quote Link to comment Share on other sites More sharing options...
Ray Posted June 26, 2022 Author Share Posted June 26, 2022 2 minutes ago, Regulo said: just get one that fits! That indeed is the plan! 😂 Quote Link to comment Share on other sites More sharing options...
annv Posted June 26, 2022 Share Posted June 26, 2022 Hi Ray the air vent that is open to the air above the tank top to hull fitting is to allow any air pressure to release from the tank is userly 3/4 inch. the air vent for the pump out is 1 1/2 inches this is userly at the side of the pump out cap on the deck and is only opened when pump out hose is connected to allow air to replace the contents when they are sucked out to stop tank imploding. John 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 26, 2022 Author Share Posted June 26, 2022 Thank you John 👍 Quote Link to comment Share on other sites More sharing options...
annv Posted June 26, 2022 Share Posted June 26, 2022 Hi Ray suggest you get the odour free wire supported hose from LeeSan this doesn't have to be thick as it only carries air (smelly air) just make sure you dont kink the hose. and the hull fitting which has a gauze filter isn't blocked. John 1 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted June 26, 2022 Share Posted June 26, 2022 9 hours ago, Ray said: It's the only bit I haven't replaced, seems like a good idea... hopefully 😁 Ah, not the large waste carrying ones, the much thinner one that allows pressure to equalise in the tank itself... I was thinking about 1/2" possibly? just be careful that the air can get in as quickly as a decent pump can suck it out as otherwise the tank will collapse, I think they are usually the sam in as well as out.. 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted June 26, 2022 Share Posted June 26, 2022 I was always in the belief of the vent shound be the same size as the feed, that pumpout can do far quicker than your rectum, unless you are drinking the wrong stuff.... 2 Quote Link to comment Share on other sites More sharing options...
Regulo Posted June 26, 2022 Share Posted June 26, 2022 Air can get through a pipe quicker than liquid/toilet mush. The vent pipe should be just that - to vent the tank. Of course there must be a way of getting air in, but the pipe doesn't need to be the same diameter as the sucky out pipe (1.5 or 1.75 ins). Never seen a vent skin fitting that size. Quote Link to comment Share on other sites More sharing options...
floydraser Posted June 27, 2022 Share Posted June 27, 2022 23 hours ago, Ray said: Ah, not the large waste carrying ones, the much thinner one that allows pressure to equalise in the tank itself... I was thinking about 1/2" possibly? "Ones", in the plural? Mine has a large input, large output (pump out), and large vent to the side of the hull. In addition there's a smaller diameter flush which has a cap next to the pump out. I replaced this with "Bosphorous Sanition Hose 19mm" from Lee Sanitiation. It's 19mm id, 27mm od and I have a bit left 39 inches long which is yours if you're not in a hurry. 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 27, 2022 Author Share Posted June 27, 2022 That's very kind, thank you. I have unwittingly confused the issue with my first post though I fear. It is the much narrower "tube" that runs from a small outlet on the top of the holding tank to a grill on the opposite side of the boat to the pumpout and flush openings on the deck. It equalises pressure in the tank as waste is pumped into it from the wc. In fact AnnV (John) above identified what I was trying to say and I now have an order in for the correct hose. My apologies to everyone trying to help me, it is not knowing the correct terminology that gets me into trouble... but I'm learning 👍 Quote Link to comment Share on other sites More sharing options...
Mouldy Posted June 27, 2022 Share Posted June 27, 2022 On 26/06/2022 at 09:32, Mouldy said: Uh-ho! Ray, this might not end well! You know what happens when you start these ‘little’ jobs!! 😉 Told you!! 😉😁 1 Quote Link to comment Share on other sites More sharing options...
Ray Posted June 27, 2022 Author Share Posted June 27, 2022 40 minutes ago, Mouldy said: Told you!! 😉😁 I can't help it I have this thirst for knowledge... maybe I should stick to my thirst for beer? 🍺🍺 😂 1 1 Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted June 27, 2022 Share Posted June 27, 2022 5 hours ago, Ray said: That's very kind, thank you. I have unwittingly confused the issue with my first post though I fear. It is the much narrower "tube" that runs from a small outlet on the top of the holding tank to a grill on the opposite side of the boat to the pumpout and flush openings on the deck. It equalises pressure in the tank as waste is pumped into it from the wc. In fact AnnV (John) above identified what I was trying to say and I now have an order in for the correct hose. My apologies to everyone trying to help me, it is not knowing the correct terminology that gets me into trouble... but I'm learning 👍 Ray Please take no offence but unwittingly confused and much narrower smaller tube are an age thing, and absolutely nothing to do with your boat..kindest Regards Marge and Parge 2 Quote Link to comment Share on other sites More sharing options...
