TerryM Posted April 7, 2023 Share Posted April 7, 2023 I have a Vetus bilge water strainer fitted to my vessel. I am informed by a BSS inspector that the Broads Authority no longer allow these filters and as such can cause a vessel to fail a BSS inspection. Brian Wards in Brundall say that their cheapest BA approved strainer is a Wavestream unit costing about £140 plus the fittings costing another £10. Have other boaters had problems with their boats passing the BSS due to having unapproved bilge strainers? Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted April 7, 2023 Share Posted April 7, 2023 Afaik,and I’m happy to be corrected, the BSS examination is not area specific?? I had my inspection done last week and the examiner didn’t seem to look at the bilge pumps,if he did it was very cursory.I have no strainers /filters fitted at all. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted April 7, 2023 Share Posted April 7, 2023 The bss inspector is talking crap, bss is nowt to do with the broads it's inland waterways in general, bss doesn’t allow a bilge pump from under an engine unless an oil catch tray is in place but strainers don't come into it. Unless of course he is talking about an oil separator of some sort, in which case just get an oil tray for under the engine if you can't move the pump to elsewhere. Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted April 7, 2023 Share Posted April 7, 2023 Remove the bilge pump and get it reinspected then refit it. Simples. Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted April 7, 2023 Share Posted April 7, 2023 I’m failing to understand what bilge pumps have to do with boat safety Ive no drip tray,engine bilge turned on. BSS chap never even looked or asked me. maybe you chaps/chappesses on the east coast need to find some non jobsworths. he was interested in ventilation,gas ,electrical install and fire fighting etc the stuff that stops you dying. Quote Link to comment Share on other sites More sharing options...
TerryM Posted April 7, 2023 Author Share Posted April 7, 2023 Thank all for you comments. I will contact the Broads Authority next week and will let you have details of their reply. Quote Link to comment Share on other sites More sharing options...
stumpy Posted April 7, 2023 Share Posted April 7, 2023 We have a Wavestream filter, it removes oil and other pollutants from the bilge pump outlet, dead simple cartridge filter. Passed three BSS tests so far, apparently you can drink the output but I've never tried it. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted April 7, 2023 Share Posted April 7, 2023 What boat and engine setup? Quote Link to comment Share on other sites More sharing options...
TerryM Posted April 8, 2023 Author Share Posted April 8, 2023 Yacht with BMC 1500cc engine Smoggy. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted April 8, 2023 Share Posted April 8, 2023 So under engine is the deepest part of bilge then, oil catch tray is the solution for bss, but oil absorbing pads (also hold diesel) work really well and float on water so it can be pumped out underneath fairly cleanly, I always have them under my engines as it keeps the grp a lot cleaner. Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted April 8, 2023 Share Posted April 8, 2023 If the bilge hoses are not attached when the bss is done then you do not need to have filters fitted . Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted April 8, 2023 Share Posted April 8, 2023 Part 9 page 81 https://www.boatsafetyscheme.org/media/299273/bss-examination-checking-procedures-interim-public-version.pdf Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted April 8, 2023 Share Posted April 8, 2023 From the above if the bilge pump draws from the engine catch tray or sealed area it needs a filter if it takes water from elsewhere it does not. If it’s the former the owner should be encouraged to remove it and no record noted. 1 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted April 8, 2023 Share Posted April 8, 2023 On Cerise Lady , the engine bilge hoses were in the bottom of the bilge , I was informed that if the hoses were in place for my BSS then they would fail it but if the hoses were removed from the bilges whilst the test was conducted then it would pass 1 Quote Link to comment Share on other sites More sharing options...
TerryM Posted April 8, 2023 Author Share Posted April 8, 2023 Some very interesting replys. However, should this actually be a boat safety matter anyway. Bilge strainers have nothing to do with gas, fuel or electric. Surely this is an environmental matter, nothing to do with the safety of the vessel being either on the mooring or out on the river! Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted April 8, 2023 Share Posted April 8, 2023 2 hours ago, TerryM said: Some very interesting replys. However, should this actually be a boat safety matter anyway. Bilge strainers have nothing to do with gas, fuel or electric. Surely this is an environmental matter, nothing to do with the safety of the vessel being either on the mooring or out on the river! Personally I don’t think it should be anything to do with boat safety certificate, It should be down to the relevant rules of the waterways the boat is on, much like toilet holding tanks etc Quote Link to comment Share on other sites More sharing options...
JanetAnne Posted April 9, 2023 Share Posted April 9, 2023 Surely the real issue here is the pumping of oils and fuels into the rivers. Agreed, it's not a safety issue for the boat itself but, whilst it's part of the BSS, at least someone is checking it! 1 Quote Link to comment Share on other sites More sharing options...
annv Posted April 9, 2023 Share Posted April 9, 2023 Hi Be aware that Wavestream filters require a stronger pump and as they collect any oils they gradually become blocked and stop the pump from working. you dont need a filter fitted to a bilge pump, engines should now have a tray or a self contained space under the engine and gear box to collect and hold all drips. Bilge filters were used before this requirement for a contained space/tray came into force on all inland water ways. If they become blocked they will stop the pump from working and could possibly sink your boat . John Quote Link to comment Share on other sites More sharing options...
Smoggy Posted April 9, 2023 Share Posted April 9, 2023 So why was a ba guy inspecting your boat in the first place? Or was it a bss guy and slip of the keyboard? Quote Link to comment Share on other sites More sharing options...
TerryM Posted April 9, 2023 Author Share Posted April 9, 2023 It was BSS Smoggy! Quote Link to comment Share on other sites More sharing options...
