LadyPatricia Posted April 1, 2015 Share Posted April 1, 2015 Question is, what is the correct way to put them together I've tried a couple of ways but nothing "looks" right HELP !!!!! Steve 1 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted April 1, 2015 Share Posted April 1, 2015 At least it has rings on it...! You probably had it right the first time Quote Link to comment Share on other sites More sharing options...
LadyPatricia Posted April 1, 2015 Author Share Posted April 1, 2015 Best I can do It works for me Steve 2 Quote Link to comment Share on other sites More sharing options...
BroadScot Posted April 1, 2015 Share Posted April 1, 2015 Where are all these retired Royal Navy types when you require one Steve Iain 1 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted April 1, 2015 Share Posted April 1, 2015 Hi Steve, On ours I like yourself put the toggle through the top ring and just tied off the string on the bottom ring. Your way looks ok to me, but I prefer knots. Keep flying our NBN flag Regards Alan 4 Quote Link to comment Share on other sites More sharing options...
LadyPatricia Posted April 1, 2015 Author Share Posted April 1, 2015 Thanks Alan I've actually remove the wooden toggle now and both top and botton spliced parts are connected as you would a key on a key ring Looks good, will look even better when it on the boat Steve 2 Quote Link to comment Share on other sites More sharing options...
Viking23 Posted April 1, 2015 Share Posted April 1, 2015 Those flags are designed to be hoisted, several can be toggled together, to go to the cross trees. For your application, I might consider pushing out the toggle and using cable ties, but if you want to lower the flag daily or for each trip, leaving the flag staff in place, then what you have done looks fine. 1 Quote Link to comment Share on other sites More sharing options...
LadyPatricia Posted April 1, 2015 Author Share Posted April 1, 2015 The final cut Steve 3 Quote Link to comment Share on other sites More sharing options...
deebee29 Posted April 1, 2015 Share Posted April 1, 2015 Hi Steve I've attatched the toggle to the top ring and shortened the bottom line by cutting the stitch that creates the loop then re-stitched the loop using a heavy waxed thread then coated the stitch in glue. I then attached the new loop to the bottom ring. I've also put a couple of cable ties round the bottom. I might remove the toggle as well (just got the flagpole this morning) I'll try to get a picture later David Quote Link to comment Share on other sites More sharing options...
deebee29 Posted April 1, 2015 Share Posted April 1, 2015 Here is my effort so far David 1 Quote Link to comment Share on other sites More sharing options...
ZimbiIV Posted April 1, 2015 Share Posted April 1, 2015 A word of warning to anyone trying to sleep near one of those poles, fasten the metal rings so they cannot rattle in the wind. I took ours down until I can work out a way. We sleep in the bow and on a windy night sleep was rare. paul 3 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted April 1, 2015 Share Posted April 1, 2015 I think we are meant to tie the top bit to another "rope" using by a bowline around the top timber bit (as so it can theoretically be hoisted and lowered) and the bottom line tie to the pole using a "Half Hitch Knot".. (although ours is just as you guys have done.. Plus I suspect the rings have been implemented now to make do as you've done!) Also don't forget the burgee should only be flown whilst the owner/skipper is on or nearby the boat (in the pub still applies). (Also don't forget the ensign should only be flown as above although should be taken down at dusk and put back up in dawn)... 2 Quote Link to comment Share on other sites More sharing options...
BuffaloBill Posted April 1, 2015 Share Posted April 1, 2015 A word of warning to anyone trying to sleep near one of those poles, fasten the metal rings so they cannot rattle in the wind. I took ours down until I can work out a way. We sleep in the bow and on a windy night sleep was rare. I fitted a short canopy bungie cord to ours which stops the rings from rattling but the pennant can make a racket on really windy nights so take it down at those times. Quote Link to comment Share on other sites More sharing options...
LadyPatricia Posted April 1, 2015 Author Share Posted April 1, 2015 It would appear a couple of strategically placed small cable ties could be in order to stop any noise Steve 1 Quote Link to comment Share on other sites More sharing options...
BroadScot Posted April 1, 2015 Share Posted April 1, 2015 Ah its good to see my old trade comes in handy on the Broads. Cable Ties rool! If they aint on flag poles, its car wheel covers! Everything, bar what they were designed for Iain 2 Quote Link to comment Share on other sites More sharing options...
BroadScot Posted April 3, 2015 Share Posted April 3, 2015 Well, it has ARRIVED! Yipppeeeee! No not Easter, My NBN Burgee. What excellent quality I must say. Thank you for the stickers and cards also Skipper. Iain 3 Quote Link to comment Share on other sites More sharing options...
Liberty Posted April 3, 2015 Share Posted April 3, 2015 +1 for the shock cord. Elastic is completely needed or it will drive you insane at 3am. What about on the cross trees? Quote Link to comment Share on other sites More sharing options...
