BrundallNavy Posted April 9, 2018 Share Posted April 9, 2018 I have just become the proud owner of the above clock. The clock was used in the factory at Moore’s in Wroxham for a variety of uses including operating the black out shutters, I’m guessing that it runs off some sort of electrical power source but information is somewhat confusing. Has anyone seen or had dealings with this type of clock as I would love to get it working again. 6 Quote Link to comment Share on other sites More sharing options...
Guest Posted April 9, 2018 Share Posted April 9, 2018 23 minutes ago, brundallNavy said: I have just become the proud owner of the above clock. The clock was used in the factory at Moore’s in Wroxham for a variety of uses including operating the black out shutters, I’m guessing that it runs off some sort of electrical power source but information is somewhat confusing. Has anyone seen or had dealings with this type of clock as I would love to get it working again. If the seals are unbroken, maybe it is still under guarantee?? Quote Link to comment Share on other sites More sharing options...
Aristotle Posted April 9, 2018 Share Posted April 9, 2018 I think Eric at Cox's Boatyard used to work at Moore's - it's just possible he might know something about it ..... Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted April 9, 2018 Author Share Posted April 9, 2018 After a bit more research I tried a 9v battery, the clock did start to work but my did I get a belt from the terminals that I was holding the wires on. I think I need to get the soldering iron out. 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 9, 2018 Share Posted April 9, 2018 have you looked here - http://pulsynetic.eu/ Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted April 9, 2018 Author Share Posted April 9, 2018 19 minutes ago, grendel said: have you looked here - http://pulsynetic.eu/ Yes but my clock doesn’t appear on the web site, I have managed to find one on google but doesn’t give much info. Even if I get it working I still need to work out how to adjust it. Quote Link to comment Share on other sites More sharing options...
Simon Posted April 9, 2018 Share Posted April 9, 2018 ive never seen anything like this. looks a great piece of kit 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 9, 2018 Share Posted April 9, 2018 looks like you have a programmer - activated by the master clock, this can for example ring a school bell at set times. now all you need is a master clock to run it. bottom of this page http://www.electrokinetica.org/d2/4/index.php Quote Link to comment Share on other sites More sharing options...
Ray Posted April 9, 2018 Share Posted April 9, 2018 It's one of those things I look at and think "I love it... what is it?" :) 3 Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted April 9, 2018 Author Share Posted April 9, 2018 1 hour ago, grendel said: looks like you have a programmer - activated by the master clock, this can for example ring a school bell at set times. now all you need is a master clock to run it. bottom of this page http://www.electrokinetica.org/d2/4/index.php That’s interesting, I’m led to believe that this was a stand alone item which did control the clocking in machine break time bells and also the blackout shutters, I think I might have to do a bit more investigation into whether this is true. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted April 9, 2018 Share Posted April 9, 2018 I'm so chuffed it is now in your ownership / care, coming from Moores what with you also owning a genuine Moores woody to - Fantastic combination. As you say more research needed, hopefully an ex Moores employee maybe able to help. Griff Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted April 9, 2018 Share Posted April 9, 2018 3 hours ago, grendel said: have you looked here - http://pulsynetic.eu/ that looks exactly like the clock in the circuit on the label, I have impulse clocks in some of the modern schools we look after, today we had one where all the clocks showed 12 o clock....some one had turned the master clock off, we turned it back on and hey presto, all the clocks motored to the correct time!....,works via a radio signal . bit of a coincidence, this should come up on the same day! Quote Link to comment Share on other sites More sharing options...
SteveO Posted April 9, 2018 Share Posted April 9, 2018 You can buy old master clocks that would drive your programmer from Ebay - from around £50, if you fancy a project. Quote Link to comment Share on other sites More sharing options...
deebee29 Posted April 10, 2018 Share Posted April 10, 2018 11 hours ago, brundallNavy said: Yes but my clock doesn’t appear on the web site, I have managed to find one on google but doesn’t give much info. Even if I get it working I still need to work out how to adjust it. Looks like the C69 programmer without the casing from the other devices page on the site http://pulsynetic.eu/other-devices/programmers-reflex/ Quote Link to comment Share on other sites More sharing options...
