johnb Posted August 12, 2018 Share Posted August 12, 2018 Owing to a misunderstanding between my wife and I (apparently I "wasn't listening!) we left our boat with a leak over our grand daughters bed. We are going back today so I may need to sort this out whilst it is raining. It must be getting in around the handrails so I am hoping just to unscrew a little and get some sealer underneath. (Optomism). I remember reading of some very effective sealer that can be applied in the wet-can anyone advise please? Thanks. Quote Link to comment Share on other sites More sharing options...
Polly Posted August 12, 2018 Share Posted August 12, 2018 Captain ????'s Crack finder from Norfolk Marine, brilliant stuff.This is a liquid and will run into the path of the leak, then you can bed in your handrails with Sikaflex or whatever when it's not raining! Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted August 12, 2018 Share Posted August 12, 2018 To give it its full title:- Captain Tolleys Creeping Crack Cure - It's good stuff and does just what it says on the bottle. We have used it far too many times tbh Griff https://www.amazon.co.uk/Captain-Tolleys-Creeping-Crack-sealer/dp/B003T6EJ9A/ref=sr_1_1?ie=UTF8&qid=1534058048&sr=8-1&keywords=captain+tolleys+creeping+crack+cure 1 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted August 12, 2018 Share Posted August 12, 2018 Had to use it in anger on the window in a rented caravan when we were up on the Solway wildfowling and it did indeed effect a cure. For permanent repair I like Dow Corning Geocel Marine Sealant. Will cure under water etc and it is available in small quantities. Unless doing a large job I find however well I seal the tube after use when I come to use it again it has set solid. Quote Link to comment Share on other sites More sharing options...
johnb Posted August 12, 2018 Author Share Posted August 12, 2018 Thank you all, I have some of the crack sealer but was unsure if it would work when raining which unfortunately seems possible Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted August 12, 2018 Share Posted August 12, 2018 If you are using Captain Tolleys make sure you put something under where it leaks is it can run through until it fully seals. 1 Quote Link to comment Share on other sites More sharing options...
vanessan Posted August 12, 2018 Share Posted August 12, 2018 I do thank you guys for these and other such posts. I usually read about various products, remedies and suchlike and invariably find myself thinking how useful something might be. I bookmark anything I think may be of interest and, when the time is right, mention it to the boss. Sometimes he’s quite impressed and I can see him thinking ‘mmm, perhaps she does have her uses’!! So, thank you. 2 2 1 Quote Link to comment Share on other sites More sharing options...
dnks34 Posted August 12, 2018 Share Posted August 12, 2018 When sealing stanchion bases or anything else thats screwed or bolted down you will get better results with a sealant thats compressible. Basic silicone sealants tend to be squeezed out which doesnt leave much of a gasket between the mating surfaces. I used to use Sikaflex but now I prefer to use CT1 in clear if its for exterior fittings as i think it cleans up leaving a neater finish. Captain Tolleys is good to use around window frames where the silicone between the glass & frame leaks but as said it has to be run in dry or it will continue running through, not set and just end up making a mess. If used dry it can hold up for a long time if your lucky but many times the only reliable way to sort it out is with a proper window refurb/reseal. I have done this myself and found captain tolleys in the frame wet months after putting in so as good as it can be it can still be hit & miss. Its certainly a worthwhile emergency item to have onboard. Leaking windows espeacially if onto beds or bedding can be a big PITA and I think really spoil the onboard experience. 2 Quote Link to comment Share on other sites More sharing options...
WherryNice Posted August 12, 2018 Share Posted August 12, 2018 I'm led to believe that the trick with silicone sealer is to not fully tighten the fixings for whatever it is you are sealing until the silicone has cured and formed a good gasket between the two surfaces first... 1 1 Quote Link to comment Share on other sites More sharing options...
annv Posted August 12, 2018 Share Posted August 12, 2018 Hi John I use geocel 201 it's a frame sealer that's uv resistance it sets like a hard rubber if you place under a fitting don't tighten leave a little loose then when it has hardened of screw up tight, oh and don't forget a smear under the screw heads.John 1 Quote Link to comment Share on other sites More sharing options...
KaptinKev Posted August 23, 2018 Share Posted August 23, 2018 On 12/08/2018 at 08:16, BroadAmbition said: To give it its full title:- Captain Tolleys Creeping Crack Cure - It's good stuff and does just what it says on the bottle. We have used it far too many times tbh Griff If shares ever come up for B.A, you can count me out. 1 Quote Link to comment Share on other sites More sharing options...
