Best Speed App ?
lakesailor
1 hour ago, CambridgeCabby said:
, if you’re hiring an older boat then usually there is a plate by the dash giving the approximate speeds at indicated revs which when we hired we found these to be a good indication of the true speed .
That's the opposite of my experience. Speed is so tide-dependant as to make any suggested rev number misleading.
but its the speed through the water and wash created that are critical, make too much wash, and even if you are below the speed limit, the rangers will let you know.
Water Rail is at about 5mph at 2000 rpm (thats the  only marking on the rev counter).
Martham boats dont even have rev counters.
On 17/07/2017 at 07:21, LondonRascal said:
Hi Robin, this doesn't work with Android 12. Do you know if there is a later version please?
You are correct but if you stick by the rpm figures the chances are the rangers won't give you a second glance evin if you are speeding due to tide as the wash will still be appropiate to the river, I've gone through reedham at just over idle well over the limit and had a cheery wave from the quay warden and seen them shout at folk below the limit pushing hard against the tide, they know the difference and it's wash they look for, the use of speed camera guns does grate with me as they are just not relavant on running water.
Well, that's reinvigorated this thread and no mistake. :default_biggrin: I've opted for the AscendApps one suggested by Gallipoli but it wasn't free. Still, at least a paid app is free of ads. I'll see how I get on with it and report back. I probably won't be out on the boat again for around a month but will try it out in the car or even just on foot.
The reason for wanting it is that being new to the Southern rivers I was very surprised to find how fast the currents can run. I was on the Yare going towards Norwich on a rising tide and my Nasa log was showing 5.5mph but the trip took considerably less time than I'd estimated, so I wanted something to give me speed over the ground. It'll be interesting to compare the two which will give an idication of the speed of the current.
A fellow boater showed me Aweigh and it looked extremely useful but my wife found a number of negative reviews of it, including significant inaccuracies in tide calculations and it sometimes failing to show speed so I decided against it.
I've been using an old TomTom but it only shows integer mph so I could be going at 4.9mph and it only shows 4 (assuming it doesn't change at the 0.5 point). In certain locations it seems to lose satellites and stops updating, hence the need for something better and more accurate. Surprisingly it does seem to know I'm driving down the river but inevitably jumps to the nearest road where there is one.
As I said earlier the speed problem with Aweigh is the reason I decided against it.
40 minutes ago, MauriceMynah said:
My garmin gives 1 decimal place so x.y
I would imagine that as so many cars have satnav as standard, there may be quite a few second hand garmins on fleabay.
Actually, I think the opposite seems to be the case, at least on lower end models.
SatNav is expensive to develop and fit into cars, as there are so many model variants of head unit to support in relatively low volumes. Now, with SatNav hardware being installed on so many phones, with loads of apps available, cars tend to have Android Auto or Apple Car Play, so you just hook your phone up to the car instead. No built-in SatNav needed so money saved by the car manufacturers.
MMtracker is very good on android and will use .qct maps as used with older versions of memory-map, I have the 1:25k OS broads map and it tracks spot on and gives accurate speed.
Downside is you can't get it through play store, I can pass on the .apk file if anyone wants a copy along with the broads map, PM me.
  • 2 months later...
I finally got the chance to try out the Ascend Apps Speedometer Plus and must say I'm really pleased with it. It does exactly what I wanted and has useful features that I don't specifically need but which are quite handy such as elapsed time and distance travelled. I installed it on my 7-year-old Samsung S5 and it works fine and leaves my current phone free.
As I have a NASA Clipper log it was interesting to get a feel for the speed of the current. The difference between speed over ground and speed through water got close to 2mph occasionally and was frequently around 1.5mph.
Thanks to everyone who offered suggestions.
6 hours ago, Smoggy said:
The paddle wheel speed logs are notoriously unreliable and often inaccurate
I can believe that. After a month on the berth the log wasn't working until I reached a section of river where I could go above 4mph so I wouldn't be at all surprised if the paddlewheel was clagged up and not rotating freely.
