mikeyboy1966 Posted November 10, 2022 Author Share Posted November 10, 2022 I was pondering whether to just varnish the deck boards but there’s a few too many screw holes and damage from previous keepers prizing the boards up,so I’ll laminate these the same as the saloon as I still have some robbins elite 4mm sapele ply,I’ve enough to do the forward cabin as well Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted November 12, 2022 Author Share Posted November 12, 2022 That’s the two main boards laminated, one smaller one to do,then I can paint and varnish 2 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted November 18, 2022 Author Share Posted November 18, 2022 I finished off laminating the boards,3x coats of Danboline paint. 2 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted November 18, 2022 Author Share Posted November 18, 2022 Although these floor boards are fixed down with nothing of interest under them,they are a snug fit so I’ll fit a pair of lifting handles so I don’t have to resort to prizing them up with a lever. one down 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 18, 2022 Share Posted November 18, 2022 24 minutes ago, mikeyboy1966 said: with nothing of interest under them Until it's water under them, then it'll be of interest, good idea with the handles. Can you stow beer under them? 1 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted November 18, 2022 Author Share Posted November 18, 2022 Ha! skived off work early, second lifting handle fitted 1st coat of varnish. Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted November 18, 2022 Author Share Posted November 18, 2022 Forgot to add photo 3 1 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted November 20, 2022 Author Share Posted November 20, 2022 I know you cant see under the floor but no harm in giving things a freshen up while the floor is up. before and after 7 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted November 28, 2022 Author Share Posted November 28, 2022 That’s the rear floor sorted. 9 1 Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted November 29, 2022 Share Posted November 29, 2022 That looks absolutely wonderful. 1 Quote Link to comment Share on other sites More sharing options...
Regulo Posted November 29, 2022 Share Posted November 29, 2022 Feeling the inspiration for a clean up, MM? 1 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted November 29, 2022 Share Posted November 29, 2022 I’ve seen some wonderful flooring made from beer bottle tops 1 Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted November 29, 2022 Share Posted November 29, 2022 12 hours ago, Regulo said: Feeling the inspiration for a clean up, MM? Well, you never know. ! Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 Next on the job list, new battery box, made from 18mm marine ply( though I must say I wasn’t overly impressed with the quality when compared to robbins elite) I’ve given it two coats of danboline so it’s ready for 1st fix electrics. Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 I bought 2x new batteries to go with the two I bought in the summer. 3xdomestic 1x starter Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 50mm sq tinned copper cable, reassuringly expensive Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 I decided to solder the ring terminals on . seemed to go well! Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 One down. Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 Job done ✅ Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted December 15, 2022 Share Posted December 15, 2022 We were told that grimped.are better for BSS they can't come apart in the heat of a fire. Can only comment on what we were advised. You are making a beautiful job of your boat both stunning and reliable. Well done you Kindest Regards Marge and Parge 1 Quote Link to comment Share on other sites More sharing options...
astonsong Posted December 15, 2022 Share Posted December 15, 2022 I think you should use silver solder because it has a higher melting point 1 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 Righto, belt/braces I’ll crimp as well 1 Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 Not disagreeing with the above but surely if there was a fire sufficient to melt the solder on top of the batteries it would melt the lead posts and the batteries would be on fire as well? so I recon the solder melting would not really be much of a issue Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 Anyways. my plan. the “box” as you look at this photo is viewed from the rear. I intend to link all of the return/earth battery terminals together and exit the box with a through panel connector on the left side of the box at the front. and onto a bus bar. the 3 domestic battery positive will be linked and exit the box through the right hand side rear,again with a through panel connector. the domestic +ve will go to a mega fuse box then onto the isolator switch. the starter battery will also exit the box through the same connectors i may fit a mega fuse on this as well so basically everything outside of the “box” is fused in case of a dead short somewhere. the “box” will be fitted with a vent to the hull on the right hand side at the front. I need to test fit the box into position on the boat before I can start drilling/fitting etc, any obvious flaws in my plan? Quote Link to comment Share on other sites More sharing options...
mikeyboy1966 Posted December 15, 2022 Author Share Posted December 15, 2022 Melting point of lead 327deg melting point of solder (lead free) 217 degree personally I think a fire on board with timber,fibreglass ,plastics,upholstery and 50 gallons of fuel is going to ,by far exceed either of these numbers. but I’ll crimp anyway Quote Link to comment Share on other sites More sharing options...
