grendel Posted April 24, 2017 Author Share Posted April 24, 2017 tonight I have worked out how to mount the LED's in the back of the lamp, that and shaping another plank ready for steaming tomorrow. 2 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted April 24, 2017 Share Posted April 24, 2017 Lighting was one of the things I agreed with Charlie, We did too but I was referring to Nav Lights, I had no idea you was going to have working lights in the wheelhouse You'll be backlighting the dials on the helm next - NO - Don't even go there! Griff 4 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 25, 2017 Author Share Posted April 25, 2017 tonight I have been playing with lights, seeing what voltages work, and how they look mounted on a bulkhead, plus steaming and clamping the plank I shaved down to size yesterday. this is what the lights look like running on 6volts 4 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 26, 2017 Author Share Posted April 26, 2017 glued that plank in position tonight, not a lot else today. 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 27, 2017 Author Share Posted April 27, 2017 tonight we have a new plank shaped steamed and clamped, I have found that I can now hold planks on with the deep clamps I bought to do the transom. before I fitted it in place I did notice a slight bow inwards on the previous plank, so I spent a little time trimming that back to a straight edge. 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 29, 2017 Author Share Posted April 29, 2017 I was a bit busy last night, so instead, this morning I glued the plank in place. Quote Link to comment Share on other sites More sharing options...
grendel Posted April 29, 2017 Author Share Posted April 29, 2017 so this afternoon, another plank is shaped steamed and clamped. As well as that I have glued the cabin sides in place on model #1. 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 29, 2017 Author Share Posted April 29, 2017 So a little more work on model #1, the cockpit floor is being constructed, supports across the width at the bulkheads, then some longitudinal supports fitted, once they have dried, the pieces bridging the doors will be cut out, to allow the steps down to the lower level to be constructed. on other thoughts, having seen the picture Charlie posted over on the Broad Ambition thread, showing the dashboard, while I dont think I can illuminate the dashboard, I have thought of away of switching the lights from the dash switch panels, basically you can get 6 way DIP switches that normally mount on a printed circuit, these look very similar to the switch panels on Broad Ambition 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted April 29, 2017 Author Share Posted April 29, 2017 next I am planning to make some beams with a groove down one face, these will make the vertical parts that support the window sashes, I wont be going to the extent of the sash chains though. 2 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted April 29, 2017 Share Posted April 29, 2017 I wont be going to the extent of the sash chains though. I should think not n'all Griff Quote Link to comment Share on other sites More sharing options...
grendel Posted April 30, 2017 Author Share Posted April 30, 2017 the sash window support pillars have been constructed, one plank has been glued in pace. Earlier today I picked up a bandsaw from the boot fair, it needed a little work, a bracket to hold the motor capacitor and a new cover fixing screw, these were immediately designed and printed, it was missing the blade, and I correctly guessed that this was why it had been abandoned, the motor tests out well. 2 Quote Link to comment Share on other sites More sharing options...
Bound2Please Posted May 1, 2017 Share Posted May 1, 2017 Looks like a Burgess oldie had one in the 80's great bit of kit Grendel Charlie Quote Link to comment Share on other sites More sharing options...
grendel Posted May 1, 2017 Author Share Posted May 1, 2017 yes indeed it is a Burgess Quote Link to comment Share on other sites More sharing options...
grendel Posted May 1, 2017 Author Share Posted May 1, 2017 well the sash pillars have been cut just a shade long, I have cut some pieces to the correct length and wedged them into the pillars to make sure they are equally spaced all the way down, next to glue them in place. 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 1, 2017 Author Share Posted May 1, 2017 and glued in place now. 4 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 2, 2017 Author Share Posted May 2, 2017 all I did this evening was to remove the clamps and check that the movement of the parts in the sash pillars works, which it does. now the sashes can be made. 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 2, 2017 Author Share Posted May 2, 2017 I also spent some time today working out the backing plate details for the lights, one stainless steel plate and a wood plate will do the trick. 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 3, 2017 Author Share Posted May 3, 2017 This evening just a little bit of fine work, this is the metal mounting for a light fitting, the wooden backing will then be shaped, I just felt that the chrome mount should be represented, this one will need some more careful filing before its ready 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 4, 2017 Author Share Posted May 4, 2017 The stainless steel plate has now been temporarily attached to a light fitting with double sided tape ready for detail filing to take place, because the fittings are thermal plastic, power tools cannot be used as these would get too hot, though once one is completed a stack of repeats can be done using a diamond disc in my dremel drill. 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 4, 2017 Author Share Posted May 4, 2017 so bearing in mind this is my first attempt at this fine work, I think I might need to have another go, but here is my attempt 1 4 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 5, 2017 Author Share Posted May 5, 2017 Tonights work was preparing another plank, then steaming and clamping it in place 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 6, 2017 Author Share Posted May 6, 2017 On 4/24/2017 at 3:30 PM, grendel said: Just dont expect me to fit the light switches in to the helm position well as it happens, fitting light switches is actually easier than I originally thought, once I started thinking how I would represent the console switches on the dashboard, it came to me that the small DIP switches seen on many motherboards would be a good representation of the dashboard console switches, with the actual switch levers a scale size. so a quick (and cheap) ebay purchase later and the switches arrived, up earlyish this morning and I satdown with my coffee to think about the dashboard. I made this one out of a lime wood (linden or boxwood) venetian blind slat. the technique for cutting the holes out to take the switches is similar to that used in full size, holes were drilled in the corners (1mm) to stop the wood splitting out, I have a box of drill bits ranging from 0.4mm to 3.2mm in 0.1mm steps. a small finger drill was used, then a scalpel was used to cut the lines, and the holes were filed out to size with a diamond grit file. I may redo this part using 1/16" or 1/32" plywood, as these slats are quite thick, the switches are barely coming flush at the front. the good part is that the switches can be wired up for the cabin and other lights the pictures here show as a background my reference book of photographs, which are very useful when working on the details. 8 Quote Link to comment Share on other sites More sharing options...
JennyMorgan Posted May 6, 2017 Share Posted May 6, 2017 Oh for the simplicity of a sailing boat's dashboard! 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 6, 2017 Author Share Posted May 6, 2017 I am still trying to figure what to use for the gauges. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted May 6, 2017 Share Posted May 6, 2017 2d print and stick on? Griff Quote Link to comment Share on other sites More sharing options...
