C.Ricko Posted April 4, 2017 Author Share Posted April 4, 2017 send me a sample board, I will put it in our chandlery (shop/stores/ reception) we are an approved fitter for Nanni diesel and fit a fair amount of webasto heaters and side power thrusters from JPC we have nice displays from the suppliers for these products, 1 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted April 4, 2017 Author Share Posted April 4, 2017 or come and see me, we have a marina full of very nice boats and owners. 3 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted April 4, 2017 Share Posted April 4, 2017 Just now, C.Ricko said: send me a sample board, I will put it in our chandlery (shop/stores/ reception) we are an approved fitter for Nanni diesel and fit a fair amount of webasto heaters and side power thrusters from JPC we have nice displays from the suppliers for these products, Thanks Clive ill get something sorted and be in contact.. it would look brill on the commodores upper deck too. Much cheaper than that flexi teak! 1 Quote Link to comment Share on other sites More sharing options...
BuffaloBill Posted April 4, 2017 Share Posted April 4, 2017 12 minutes ago, JawsOrca said: Much cheaper than that flexi teak! Just wondered.....but anyone know how to remove that stuff and especially that black glue holding it down! Would much prefer carpet in our cockpit which is what it had originally before someone thought it looked better with this rubbish! 1 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted April 4, 2017 Author Share Posted April 4, 2017 fein saw Bill, cut the glue while a couple of people with mole grips heave like mad! 1 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted April 4, 2017 Share Posted April 4, 2017 47 minutes ago, BuffaloBill said: Just wondered.....but anyone know how to remove that stuff and especially that black glue holding it down! Would much prefer carpet in our cockpit which is what it had originally before someone thought it looked better with this rubbish! Hi Bill, I would try an iron on a small section to see it will melt the glue enough to lift it up. If it works out OK tackle the glue left with scrapers and solutions like Nitromors assuming it is fitted to boards and not fiberglass, or maybe stickystuff remover. Regards Alan Quote Link to comment Share on other sites More sharing options...
BuffaloBill Posted April 5, 2017 Share Posted April 5, 2017 Thanks for those answers. The fake teak is about 6mm thick so I don't see an iron being any good to loosen the glue. The fake teak would melt before that happened! Also Alan, the stuff is stuck directly to the fibreglass floor so care will be needed when choosing something to dissolve that black glue stuff. It's got to come off as Jenny has said she wants carpets down Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted April 5, 2017 Share Posted April 5, 2017 Just now, BuffaloBill said: Thanks for those answers. The fake teak is about 6mm thick so I don't see an iron being any good to loosen the glue. The fake teak would melt before that happened! Also Alan, the stuff is stuck directly to the fibreglass floor so care will be needed when choosing something to dissolve that black glue stuff. It's got to come off as Jenny has said she wants carpets down Hi Bill, Can the carpet not be put on top of the fake teak? Just a thought. Regards Alan 2 Quote Link to comment Share on other sites More sharing options...
ZimbiIV Posted April 5, 2017 Share Posted April 5, 2017 Fake teak is just basically thick lino, so if you can free a small corner then use a heat gun on low to soften the adhesive a bit then wait a few seconds before scraping with a broad paper scraper. It will take a long time but will work. It took me 4 hours to lift 2sq yards! Another way is to sharpen the scraper and GENTLY force the adhesive away then if you are covering with carpet any marks will be covered, but the heat gun method does work. When I lifted the stuck down lino a quick sand then I could stain the floor, It's now covered in carpet! WOMEN!!!!!!!!!!!! paul 2 Quote Link to comment Share on other sites More sharing options...
JawsOrca Posted April 5, 2017 Share Posted April 5, 2017 Ive not had the pleasure of removing tekdeck I suspect its something we wont as its too expensive. Id say a mixture of clives method and a scaper is the way. I guess it depends if it was laid properly though as it should have grooves like a tile spreader... if not u suspect you will make a right mess. Once you.do get it off.. ive found silicon eater pastes do a good job at dissolving all types of glues.. if it was me id just lau the carpet over and spend more time in the pub ;-) 4 Quote Link to comment Share on other sites More sharing options...
BuffaloBill Posted April 6, 2017 Share Posted April 6, 2017 I don't do bodge jobs! If I do a job it has to be a proper one. Laying carpet over the Teckdeck is a no-no for me. The heat gun method may do it having thought about it but it's the glue which may be a problem. When I do sell the boat, I don't want the purchaser saying it should have been done properly etc.!! I can't live with that thought! I'm down tomorrow so will have a closer look. Alan's carpet turned Jenny's head at the Jumble last week. So that's another job for me!! 3 Quote Link to comment Share on other sites More sharing options...
ZimbiIV Posted April 6, 2017 Share Posted April 6, 2017 The adhesive (black stuff) is bitumen based so any left on the deck just heat gun again and carefully scrape away. I did it on floorboards and they were good enough to sand down then stain. If you cannot get a corner to lift just use the heat gun to soften the edge. It is important to wait about 10 seconds after heating to allow the heat to soak in and avoiding burnt hands! paul ps make sure you have plenty of ventilation, it stinks when warm. Quote Link to comment Share on other sites More sharing options...
BuffaloBill Posted April 6, 2017 Share Posted April 6, 2017 Thanks Paul. I'll look into it. Quote Link to comment Share on other sites More sharing options...
riverman Posted April 12, 2017 Share Posted April 12, 2017 Just incase anyone's still on topic, i hear there are some lovely, beautifully constructed, new mooring in Oby, not really that far from Horning. Apparently opening in may. 4 Quote Link to comment Share on other sites More sharing options...
Regulo Posted April 13, 2017 Share Posted April 13, 2017 Last Saturday that was just a big hole in the ground! Quote Link to comment Share on other sites More sharing options...
riverman Posted April 13, 2017 Share Posted April 13, 2017 No, it's a private dyke, but a very reasonably priced one (or so I'm led to believe) considering the facilies and location. Quote Link to comment Share on other sites More sharing options...
riverman Posted April 13, 2017 Share Posted April 13, 2017 Not a clue, don't even know if that will be offered. Would make good business sense until the permanent moorings are filled up, and seeing as BAM are currently pulling out the public moorings, it would be a golden opportunity but i really don't know. Quote Link to comment Share on other sites More sharing options...
vanessan Posted April 13, 2017 Share Posted April 13, 2017 I rather think these will be private moorings, similar to the adjacent dyke. The planning permission was granted subject to a 40 metre length of bank being transferred to the BA for visitor moorings. I believe these will be on the main river. No doubt there will be someone who can confirm this, or otherwise of course! Quote Link to comment Share on other sites More sharing options...
riverman Posted April 13, 2017 Share Posted April 13, 2017 That is correct, and what i originally meant, sorry for any confusion. Quote Link to comment Share on other sites More sharing options...
SPEEDTRIPLE Posted April 16, 2017 Share Posted April 16, 2017 What`s Oby, or should that be WHERE?. Quote Link to comment Share on other sites More sharing options...
tjg1677 Posted April 16, 2017 Share Posted April 16, 2017 7 minutes ago, SPEEDTRIPLE said: What`s Oby, or should that be WHERE?. Is it Ashby by oby?? Quote Link to comment Share on other sites More sharing options...
vanessan Posted April 16, 2017 Share Posted April 16, 2017 1 hour ago, SPEEDTRIPLE said: What`s Oby, or should that be WHERE?. Oby dyke and mill etc is just downstream of the Thurne Mouth and Boundary Farm moorings (or should I say ex-moorings?!). 2 Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted April 17, 2017 Author Share Posted April 17, 2017 Oby is not Horning , When finished I imagine although reasonably priced the Oby moorings will be much cheaper than most of Horning, some of horning is reasonably priced, will they have finger jetties, lighting, 16amp electricity supplies to each mooring and fresh water supplies, is there vehicular access to any moorings? is the car park far away? are there any on site facilities? Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted April 17, 2017 Share Posted April 17, 2017 I would imagine that like most things in life, you get what you pay for. The broads has moorings to suit most budgets, the cheaper ones having few facilities, the pricier ones having more. I'm still looking for one where nubile young virgins drape themselves all over the boat 24/7... Anything to keep that wretched duck poo off the decks. 5 Quote Link to comment Share on other sites More sharing options...
SPEEDTRIPLE Posted April 17, 2017 Share Posted April 17, 2017 Ah, thanks for that. Is that correct there'll be some free 24 hour moorings, and will there be public access to Thurbe village by footpath etc?. The reason I ask is I can see with the Lion being totally refurbed and under new ownership, Thurbe dyke will be extremely popular and very busy, more likely even full, so this would make a good alternative, even though you will have a 10 - 15 minute walk. Quote Link to comment Share on other sites More sharing options...
