DaveRolaves Posted November 22, 2017 Share Posted November 22, 2017 I have used the black and decker powerfile now for many years for boat building and general maintenance work. Its a good tool, well made and will last a long time. Its available with broad and narrow belt attachments. It can be bought from E Bay and other places for less than £40 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted November 22, 2017 Share Posted November 22, 2017 I have the lidl version of that for my model boat - good piece of kit. Quote Link to comment Share on other sites More sharing options...
JohnK Posted November 22, 2017 Share Posted November 22, 2017 Oooo, a power tool I don’t have (yet). A cordless version of that would be extremely useful. Thanks for sharing. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
deebee29 Posted November 22, 2017 Share Posted November 22, 2017 Got one of those as well, very useful for all sorts of jobs. Had it for years Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted November 23, 2017 Share Posted November 23, 2017 I've got the LIDL one and I use it extensively for sharpening. Rotary mower blades, hedge/lawn shears, scissors, spades, screwdrivers and just about whatever. Brill! 1 Quote Link to comment Share on other sites More sharing options...
RumPunch Posted November 23, 2017 Share Posted November 23, 2017 Had one years - that and the vibrating multi tools ( stop it ! ) are just so adaptable. Used to use air powered power files in the RAF for metal work - save so much time in skilled hands ( mind you I do remember one lad looking like he was making a relief map of a mountain range out of a panel 3 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted November 23, 2017 Share Posted November 23, 2017 Never owned a powerfile, methinks it's about time I did though. Now when will Lidl be selling them again I wonder? Griff Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted November 23, 2017 Share Posted November 23, 2017 I have one used it only once and been in the cupboard ever since. Not that impressed with it. Doug. Quote Link to comment Share on other sites More sharing options...
grendel Posted November 23, 2017 Share Posted November 23, 2017 mine gets used as a miniature belt sander on the model Quote Link to comment Share on other sites More sharing options...
ZimbiIV Posted November 23, 2017 Share Posted November 23, 2017 Wimps! paul Quote Link to comment Share on other sites More sharing options...
DaveRolaves Posted November 23, 2017 Author Share Posted November 23, 2017 I have one used it only once and been in the cupboard ever since. Not that impressed with it. Why Not Well lets see what it will do and others may well add to the list. Here are just a few things:- It will sharpen knifes, chisels garden tools. It will derust metal and remove metal burrs after cutting It will clean up those damaged threads on a bolt so you can spin a nut on to it. It will smooth off the edge of a wall tile after its been cut. It will plunge into a wooden door when you fit a mortice lock It will smooth timber, it will grind away fibre glass, metal and filler. It will grind away that part of the door that sticks in the frame. It will grind away that screw that protrudes and grind off the head if needed It will square off a length of copper tube that you have not managed to cut off square with the hacksaw. It will clean off anodes before the boat goes back in the water and smooth off a damaged prop It will enlarge that hole you have cut in the hull for fitting a skin fitting or bowthruster tube It will grind away that rusted and seized nut that you cannot remove with a spanner. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted November 24, 2017 Share Posted November 24, 2017 It will smooth off the edge of a wall tile after its been cut. It may well do with a ceramic wall tile, doubt it would do the same on a floor grade porcelain tile though. I use good quality (Expensive) dry/wet diamond blades on porcelain and they don't last for ever either! It will square off a length of copper tube that you have not managed to cut off square with the hacksaw. Hacksaw on copper tube? Never! I use proper pipe cutters, keeps the ends square with an ever so slight bevel - Perfect Griff 1 Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted November 24, 2017 Share Posted November 24, 2017 10 hours ago, DaveRolaves said: I have one used it only once and been in the cupboard ever since. Not that impressed with it. Why NOT It will sharpen knifes, chisels garden tools. The last thing you need when sharpening chisels is heat and you cannot get a flat edge with such a narrow belt, I will stick to my oil stone thanks. Doug. 1 Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted November 24, 2017 Share Posted November 24, 2017 I meant big old cold chisels, Doug. Quote Link to comment Share on other sites More sharing options...
grendel Posted November 24, 2017 Share Posted November 24, 2017 oil stone for chisels for me too, I really must find my bench grinder though, as I only have a little one with a 2" stone available at the moment, a decent bench grinder is good for straightening up a chisel found at a boot fair where the edge has been mangled. Quote Link to comment Share on other sites More sharing options...
Wildfuzz Posted November 24, 2017 Share Posted November 24, 2017 For my turning chisels which need regular accurate and repeatable grinds I use a Creusen slow speed grinder with a Robert Sorby jig. Some of the grind angles can be difficult free hand especially with a swept back wing. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted November 24, 2017 Share Posted November 24, 2017 Water stones for me rather than oil stones, they give a far better edge. Regards Alan Quote Link to comment Share on other sites More sharing options...
grendel Posted November 24, 2017 Share Posted November 24, 2017 I thought Waterstones did books? 1 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted November 24, 2017 Share Posted November 24, 2017 I suppose books can be used - to hone ones intellect. 3 2 Quote Link to comment Share on other sites More sharing options...
