Dydle
JohnK
From High6’s link
“A dydler is a person who dydles! A dydle was a tool used to dredge the rivers and ditches”
Apparently a colander type thing on a stout pole.
Plan b if I can’t get a dydle is a bucket with holes on a rope.
You can probably locate a 'swipe' from a working farm suppliers such as Atlantic at Earsham near Bungay. All you then need is a suitable stick. A 'swipe' is like a half round saucepan with a handle that your stick is shoved into. You can drill holes in it or not, personally I haven't. It's amazing just how much silt that you can shift with a dydle.
Attempt 1. Abject failure.
Pole too bendy, bucket too fragile.
Attempt 2 garden rake. Ok but not lifting much silt.
Attempt 3. Awesome!
I’m fairly sure we had too many saucepans anyway. I could probably just wash it up if required.
6 hours ago, JohnK said:
Thanks JM (I seem to say that a lot, I may soon have to forgive you for your views on the BA emoji57.png)
Is this the same Atlantic?
https://www.newatlanticonline.co.uk
Searching for swipe doesn’t return anything and I can’t see anything in hand tools. Does it have another name?
Certainly is the one. I have also searched but with no joy, surprising. They might have a posh name but on the Broads 'tis a 'swipe' or a 'dydle', depends on the actual use I suppose. Better look after mine with more care If I can't buy another.
You have boat.
You have engine.
Boat has propeller.
Tie boat securely.
Start engine.
Engage forward gear.
Push throttle right forward.
Retire to bungalow.
Sup pint of tea.
Return to boat.
Turn engine off.
Job done!
I did try that first
It did stir it up a lot but the silt seemed to stay in the mooring rather than bugger off down the river.
I’m enjoying myself with my saucepan
A good winter ebb tide helps enormously! PS the use of the 'B' word, whilst popular in Norfolk, is clearly frowned upon by city folk, bless 'em!
Perhaps Peter should have specified that you tie the boat with the stern facing out into the river?
Believe us, it works!
I’d like to have some clever response to this. But I don’t.
In my defence the shallowest water (deepest silt?) was at the back of the mooring. Perhaps I should have stirred it up there then turned the boat round!!
Thanks everyone for the advice.
We are just on the full moon at the moment, so try it at low tide, for a couple of hours.
Thanks for that. If I get bored of my dydling I will (the silt is useful to me too).
Incidentally, is the spring tide on the day of the full moon or a day or two later?
