It Can Happen To The Best Of Them!
coolcat
16 minutes ago, FairTmiddlin said:
Why was he dragging his anchor?
Panic braking - every little helps when you're trying to stop 10,000 tons. Saw it happen once at Felixstowe but I was too busy legging it to take snaps!
  • Haha 2
Collisions between cruise ships and dock walls are far more frequent than you might think, almost a daily occurrence. Cruise lines refer to it a "heavy berthing" and it's usually a result of misjudging the wind or a late change in wind direction. Once cruise ships were referred to as floating hotels, nowadays they are floating cities, the largest approaching a quarter of a million tonnes yet most of the time they approach port and dock unaided.
When a heavy berthing leads to damage then technical or mechanical faults are normally blamed. It's less embarrassing than admitting the master "cocked up".
