tomm5235 Posted September 12, 2021 Share Posted September 12, 2021 Hi Guys. My Pegasus 700 currently has a meth's hob burner which i hate and i want to get a gas hob fitted. does anyone have any recommendations of someone who would be able to do the work and any experience of cost to get it all plumbed in and set up to pass a BSS certificate? it would be on a sliding system so the hob burner would need to be on a flexible pipe as it will slide out from under a bulkhead. Thanks in advance Tom Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted September 12, 2021 Share Posted September 12, 2021 John Spruce is your man 07768 072004 2 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted September 12, 2021 Share Posted September 12, 2021 If you don't have a gas locker fitted look to get something to fit bigger than a 4.5kg butane bottle as they have been like rocking horse poo for the last two years. 3 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted September 13, 2021 Share Posted September 13, 2021 12 hours ago, CambridgeCabby said: John Spruce is your man And I am afraid I rather doubt he would recommend a sliding hob on a flexible pipe. Quote Link to comment Share on other sites More sharing options...
floydraser Posted September 13, 2021 Share Posted September 13, 2021 Try Will Kirby, Freshwater Marine. https://www.freshwatermarine.co.uk/ 1 Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted September 13, 2021 Share Posted September 13, 2021 16 hours ago, tomm5235 said: it would be on a sliding system so the hob burner would need to be on a flexible pipe as it will slide out from under a bulkhead. Thanks in advance Tom Fear you will need a Plan B for the gas hob. 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted September 13, 2021 Share Posted September 13, 2021 I'm sure a flexi is allowed for a gimballed cooker, sliding is probably another matter. 1 Quote Link to comment Share on other sites More sharing options...
floydraser Posted September 13, 2021 Share Posted September 13, 2021 I don't actually know whether flexible/sliding arrangements are allowed but if I had to guess I would say there should be a fail-safe locking mechanism to prevent anything moving when it's not meant to. I don't see a flexible pipe as a problem as they are standard on domestics. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted September 13, 2021 Share Posted September 13, 2021 3 hours ago, Vaughan said: And I am afraid I rather doubt he would recommend a sliding hob on a flexible pipe. The sliding gas hob is a very common installation on yachts up to about 27ft, often going into the quarter berth area. The Swallow 26 is an example. However these boats are designed for the sea and most will not be subject to BSS. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted September 13, 2021 Share Posted September 13, 2021 Calor also have a rarity on 3.9Kg Propane at present. 1 Quote Link to comment Share on other sites More sharing options...
marshman Posted September 13, 2021 Share Posted September 13, 2021 Which of course , may be why you have a meths installation! Nip down to S Walsham to talk to some other Pegasus 7 owners and see what they do- or indeed where ever others berth. I am sure someone on here knows of someone! But I think flexible hoses are a no no these days. Can you not think of another solution to a permanent fitting? 1 Quote Link to comment Share on other sites More sharing options...
annv Posted September 13, 2021 Share Posted September 13, 2021 Hi Flex able GAS hoses are allowed on fixed appliances however you must have a tap/valve on end of copper pipe where the flex is fitted and they must be fixed securely, i have two on my boat. I would suggest you get the 10mmcopper pipe that has a plastic outer sheath a bit dearer but corrosion free. John 1 Quote Link to comment Share on other sites More sharing options...
