Sazzajn Posted September 24, 2018 Share Posted September 24, 2018 As the colder weather starts to set in, I’ve started to think about the best ways to make sure that our boat stays in tip top shape. The marina where she is moored offer winterisation options which we will be utilising, however up until we fully winterise at the end of “our season” we are looking at tube heaters. As first time boat owners, was wondering how much power they draw down when plugged in....ie how much ££ would we expect to have to put into the marina’s power towers if we were to say leave the boat for 2 weeks? We would be looking to have 2-3 tube heaters. Any advice from experience greatly appreciated as always! Thank you. Sent from my iPhone using Norfolk Broads Network Quote Link to comment Share on other sites More sharing options...
TrevorAndDeirdre Posted September 24, 2018 Share Posted September 24, 2018 Make sure you have a thermostat as well that helps keep cost down. Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted September 24, 2018 Share Posted September 24, 2018 With thermostats on two heaters and a dehumidifier on a timer during the day, it costs about 35 pounds for October to march. Quote Link to comment Share on other sites More sharing options...
Regulo Posted September 24, 2018 Share Posted September 24, 2018 2 x 60 Watt heaters = 120 Watts. Run them for 8 hours will be 1 kW, therefore 3 units per day, therefore 21 units a week. But that would be continuously on. Use a thermostat, and you're unlikely to use anywhere near that. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted September 25, 2018 Share Posted September 25, 2018 We have two 80w tube heaters installed via a thermostat set to +2c. That is all we do for our winterisation each year, is switch them on around October to April. Works for us and no real noticeable increase in elec costs over the winter months. Being in a wetshed helps of course Griff Quote Link to comment Share on other sites More sharing options...
annv Posted September 25, 2018 Share Posted September 25, 2018 Hi Sazzigin you wont need tube heaters until after the season say Jan/Feb just ventilation and conkers to drive away the spiders, so if you are winterizing at end of season you don't need anything just lots of ventilation to stop damp whilst on the hard standing,the heaters are only to stop water freezing up in the system ,winterizing will drain/remove all water that could freeze up,tube heaters wont stop damp.John Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted September 25, 2018 Share Posted September 25, 2018 I use heaters and a dehumidifier as we use the boat all year, just drain the water system from early December, Always top up the fuel. Quote Link to comment Share on other sites More sharing options...
Sazzajn Posted September 25, 2018 Author Share Posted September 25, 2018 Hi Sazzigin you wont need tube heaters until after the season say Jan/Feb just ventilation and conkers to drive away the spiders, so if you are winterizing at end of season you don't need anything just lots of ventilation to stop damp whilst on the hard standing,the heaters are only to stop water freezing up in the system ,winterizing will drain/remove all water that could freeze up,tube heaters wont stop damp.JohnConkers??! Not heard of that before!Sent from my iPhone using Norfolk Broads Network Quote Link to comment Share on other sites More sharing options...
Sazzajn Posted September 25, 2018 Author Share Posted September 25, 2018 Thank you all for the advice / hints and tips.Sent from my iPhone using Norfolk Broads Network Quote Link to comment Share on other sites More sharing options...
Regulo Posted September 25, 2018 Share Posted September 25, 2018 Yes, conkers are reputed to repel spiders. Never tried it myself, but others swear they work. There's also a repellent spray, if they trouble you too much. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted September 25, 2018 Share Posted September 25, 2018 We have two tube heaters on each side of the engine controlled by a frost stat. It has worked for us for many years. We still winterize the boat prior to its winter service. Regards Alan Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted September 26, 2018 Share Posted September 26, 2018 If you leave conkers on the boat over winter, and in the spring come back to the boat to find most of the conkers seem to have broken up, those spiders were bigger than you thought, and you do NOT want to find the spider with the winning conker. 4 Quote Link to comment Share on other sites More sharing options...
Baitrunner Posted September 26, 2018 Share Posted September 26, 2018 19 hours ago, Regulo said: There's also a repellent spray, if they trouble you too much. I have seen the spray and wondered how good it was. Anyone tried it? I wonder if it contains conker essence? Quote Link to comment Share on other sites More sharing options...
rightsaidfred Posted September 26, 2018 Share Posted September 26, 2018 16 minutes ago, Baitrunner said: I have seen the spray and wondered how good it was. Anyone tried it? I wonder if it contains conker essence? Depends on how long you are prepared to sit there and how good your aim is. Fred Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted September 26, 2018 Share Posted September 26, 2018 Ahh yes, conker essence spider repellent. guaranteed, no strings attached. 1 3 Quote Link to comment Share on other sites More sharing options...
vanessan Posted September 26, 2018 Share Posted September 26, 2018 I have used the spray and I think it does help to keep spiders at bay. It smells of chestnuts! Mind you, I also shut windows and put plugs in basins to try and block all entry points. We’ve used confers too but the jury’s still out on that. Quote Link to comment Share on other sites More sharing options...
vanessan Posted September 26, 2018 Share Posted September 26, 2018 Not ‘confers’ - ‘conkers’ for goodness sake!! B****y predictive text! 1 Quote Link to comment Share on other sites More sharing options...
eddybear Posted September 30, 2018 Share Posted September 30, 2018 On every boat I've owned I've been plagued with spiders and the mess they make, last week I put on one of these electric sonic devices that are meant to deter mice spiders and all sorts of creepy crawlies, went to the boat yesterday Saturday, 29 September and couldn't believe the transformation not one single spider, spoke to the chap moored next to me and was telling him how wonderful this device was and he said yes there are all of my Boat now, had to laugh, As for conkers they seem to work for a lot of people being in the carpet cleaning business I'm always having to remove them from the corner of rooms before cleaning and get told off if I don't put them back. 1 Quote Link to comment Share on other sites More sharing options...
Daddy Mouse Posted September 30, 2018 Share Posted September 30, 2018 On every boat I've owned I've been plagued with spiders and the mess they make, last week I put on one of these electric sonic devices that are meant to deter mice spiders and all sorts of creepy crawlies, went to the boat yesterday Saturday, 29 September and couldn't believe the transformation not one single spider, spoke to the chap moored next to me and was telling him how wonderful this device was and he said yes there are all of my Boat now, had to laugh, As for conkers they seem to work for a lot of people being in the carpet cleaning business I'm always having to remove them from the corner of rooms before cleaning and get told off if I don't put them back.What make was it, they are in for a sales boom. Sent from the Norfolk Broads Network mobile app 2 Quote Link to comment Share on other sites More sharing options...
annv Posted September 30, 2018 Share Posted September 30, 2018 I evan planted a Chestnut/conker tree to be sure of unlimited supplies of conkers,never had them break open, they just shrivel up over time. John Quote Link to comment Share on other sites More sharing options...
Siddy Posted September 30, 2018 Share Posted September 30, 2018 12 hours ago, eddybear said: electric sonic devices that are meant to deter mice spiders and all sorts of creepy crawlies, I thought of these but anyone know of issues with dogs? Don't want one sending him crazy. I'd put them in the garage. I have critter sticky traps out of his reach but he can smell them and trys to get them. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted October 1, 2018 Share Posted October 1, 2018 We have four of them onboard 'B.A' two fwd and two aft. Prior to that we were not infested but did get some. We did however have a Rollland onboard for a weekend. We managed to flush him out, the electronic repellers have kept all unwanted guests away since. When onboard we un-plug them and put them away. Ref the dogs thing - I have some similar devices at home in the garage and loft, the dogs seem fine with them. As for which model to choose, just have a look on Amazon / Ebay and read the reviews. Hope this helps, Griff Quote Link to comment Share on other sites More sharing options...
