smitch6 Posted November 29, 2018 Share Posted November 29, 2018 anyone got a hand pump assembly for a toilet pls? i have the bowl and the base plate just need the hand pump bit thanks steve Quote Link to comment Share on other sites More sharing options...
marshman Posted November 29, 2018 Share Posted November 29, 2018 I suspect Lee Sanitation or even Norfolk Marine will have just the bit!! Quote Link to comment Share on other sites More sharing options...
eddybear Posted November 29, 2018 Share Posted November 29, 2018 Speaking from experience I would say Go and buy the complete pump unit, not the kit, I had the kit installed by a so-called competent mechanic never did work properly after that, then went to Norfolk Marine and bought the pump unit I think about £68 Hasn't missed a beat since, You can fit it yourself and about 15 minutes, regards Ted Quote Link to comment Share on other sites More sharing options...
smitch6 Posted November 29, 2018 Author Share Posted November 29, 2018 i noticed all the jabsco ones are rectangular base, mine has a square base? are they compatible? Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted November 30, 2018 Share Posted November 30, 2018 13 hours ago, smitch6 said: i noticed all the jabsco ones are rectangular base, mine has a square base? are they compatible? Hi Steve, The Jabsco pump base is oblong with rounded corners. I suggest that you check for a name on the toilet bowl or base to determine the manufacturer, failing that I would call in at Brian Wards and get Nick or Tanya's opinion on what your toilet is, remember asking for the NBN discount. Maybe if you post a picture of the toilet and the square base one of the members may know what it is. Regards Alan Quote Link to comment Share on other sites More sharing options...
Guest Posted November 30, 2018 Share Posted November 30, 2018 15 hours ago, smitch6 said: i noticed all the jabsco ones are rectangular base, mine has a square base? are they compatible? Not a great picture ...but that's what mine looks like .. Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted November 30, 2018 Share Posted November 30, 2018 Having met a number of members of this forum I have to support the decision to strongly discourage the option of "If you show me yours, I'll show you mine". Quote Link to comment Share on other sites More sharing options...
Regulo Posted November 30, 2018 Share Posted November 30, 2018 I don't want to see yours, anyway. Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted November 30, 2018 Share Posted November 30, 2018 Why not ??? It's highly functional, nicely plumbed in and does everything I want it to. I have no doubt that it's every bit as good as yours even if it does get used less. 1 Quote Link to comment Share on other sites More sharing options...
Regulo Posted November 30, 2018 Share Posted November 30, 2018 Mine's polished often, sometimes gets a bit of condensation on it, but I never let it get mouldy. Did get a bit smelly a few years back, but a good scrub cured it. (Sorry, Steve, he started it)! 1 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted November 30, 2018 Share Posted November 30, 2018 Mine empties at a mearest touch 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 30, 2018 Share Posted November 30, 2018 On 29/11/2018 at 17:47, eddybear said: I had the kit installed by a so-called competent mechanic That don't mean much unfortunately, I had a suzuki agent put my suzuki outboard together with the cam timing a mile out and try telling me it may need piston rings as it had no compression, took me less than 5 mins to work out what he had done wrong, what a plonker, don't worry he's not based on the broads he's safely in cambs. Should really do a full write up on the experience seeing as he swore on the phone at me and hung up, may get round to it. Quote Link to comment Share on other sites More sharing options...
Wildfuzz Posted November 30, 2018 Share Posted November 30, 2018 I would second putting a new pump assemble on, I did service ours last season but the plastic get brittle and a PITA... Quote Link to comment Share on other sites More sharing options...
Smoggy Posted December 1, 2018 Share Posted December 1, 2018 15 hours ago, Wildfuzz said: but the plastic get brittle and a PITA... Put the seat down then! 1 Quote Link to comment Share on other sites More sharing options...
Wildfuzz Posted December 5, 2018 Share Posted December 5, 2018 Yes I didn't word that very well did I! Quote Link to comment Share on other sites More sharing options...
