Andrewcook Posted March 30, 2021 Share Posted March 30, 2021 How often do Mooring Ropes needs to be Changed and at what stage do they need to be done? Also Fenders Ropes. Why do Mooring Ropes get knotted up? Quote Link to comment Share on other sites More sharing options...
marshman Posted March 30, 2021 Share Posted March 30, 2021 Mine don't!!!! Quote Link to comment Share on other sites More sharing options...
Bluebell Posted March 30, 2021 Share Posted March 30, 2021 39 minutes ago, Andrewcook said: Why do Mooring Ropes get knotted up? Eh? Only when tying up surely! Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted March 30, 2021 Share Posted March 30, 2021 They only get knotted if incorrectly stowed. As far as when do they need replacing provided they are not frayed it is only cosmetics that dictates replacing them . We use separate lines at our home mooring so those aboard are only in use when we are our and about Quote Link to comment Share on other sites More sharing options...
stumpy Posted March 30, 2021 Share Posted March 30, 2021 Hireboat lines are usually hairy blue polypropylene which is a b*gger to undo tight knots from without a fid or spike so they just get left. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted March 30, 2021 Share Posted March 30, 2021 They don't, well that is to say ours never have in 14 years of owning 'B.A' same goes for the hireboats we have had over the years. Having said that I have removed plenty of knots from the hairy stuff using screwdrivers / vice grips etc Once a season our mooring ropes go through the longest cycle wash in t washing machine possible with added fabric softener too. That does the trick, brings them up like new, soft and pliable too Griff 1 Quote Link to comment Share on other sites More sharing options...
NorfolkNog Posted March 30, 2021 Share Posted March 30, 2021 The blue ones do seem to be more common and are a pain if they get knotted or frayed. Often too short as well, maybe where knots have been cut out. To their credit Bridgecraft use proper rope and a decent length too. There's nothing more annoying than trying to put springs on at the likes of Yarmouth etc and finding the ropes are not long enough. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted March 31, 2021 Share Posted March 31, 2021 The benefit of polypropylene ropes is it's cheap and floats, but it's bloody horrible stuff, I usually go for double braid nylon inner with polyester outer as they wear well with a bit of stretch, I carry spare 16mm nylon 3 strand for bumpy coastal moorings as it snatches less. I find chucking mooring lines in a pillowcase before washing saves on wear. 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted March 31, 2021 Share Posted March 31, 2021 also if you are laying the rope into a coil, make sure you coil in the right direction, as if you go against the grain the rope will not lay flat to the deck, it usually takes several goes to get the mooring lines to coil nice and flat on the jewels on lads week 1 Quote Link to comment Share on other sites More sharing options...
Andrewcook Posted March 31, 2021 Author Share Posted March 31, 2021 Hi Griff now I know how you keep your Ropes Clean and Soft including the Fenders and Ropes and looking very Smart may I add when B A is out and about on the Broads 2 Quote Link to comment Share on other sites More sharing options...
