lurcher Posted June 15, 2021 Share Posted June 15, 2021 you want biblical floods? https://flood-warning-information.service.gov.uk/station/6205?direction=u Quote Link to comment Share on other sites More sharing options...
Smoggy Posted June 15, 2021 Share Posted June 15, 2021 Maybe a fat bloke has fell in beside the sensor? Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted June 15, 2021 Share Posted June 15, 2021 Definitely not that high at the moment. Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted June 23, 2021 Author Share Posted June 23, 2021 Construction finished now the fun part. First coat of varnish on. 5 3 Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted July 1, 2021 Author Share Posted July 1, 2021 Well it’s finally finished. Just need to add water. 4 6 Quote Link to comment Share on other sites More sharing options...
Lulu Posted July 1, 2021 Share Posted July 1, 2021 Beautiful. Is this Nipper’s new tender? Quote Link to comment Share on other sites More sharing options...
Victoryv Posted July 1, 2021 Share Posted July 1, 2021 Varnish up to your usual shabby standard then! 1 Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted July 1, 2021 Author Share Posted July 1, 2021 This weekend was supposed to be launch weekend but my roof rack doesn’t fit my current car, Halfords don’t yet stock the fitting kits so I had to bite the bullet and order one from BMW. Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted July 1, 2021 Author Share Posted July 1, 2021 5 hours ago, Lulu said: Beautiful. Is this Nipper’s new tender? No she is Nippers Nipper’s tender Thinking of naming her Nipper’s Nipper’s Nipper. 2 Quote Link to comment Share on other sites More sharing options...
Maxwellian Posted July 9, 2021 Share Posted July 9, 2021 Lovely work Doug Quote Link to comment Share on other sites More sharing options...
BigA Posted July 14, 2021 Share Posted July 14, 2021 On 15/04/2021 at 07:03, Timbo said: Looking good. Just one thing...have you done a Gibbs from NCIS? How you going to get it out of the conservatory? Gibbs always gets his out 2 Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted July 14, 2021 Share Posted July 14, 2021 On 15/04/2021 at 07:03, Timbo said: Looking good. Just one thing...have you done a Gibbs from NCIS? How you going to get it out of the conservatory? We learnt this week that Gibbs has an old coal scuttle, personally I`m not convinced that is the way he got the boats out. Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted July 14, 2021 Author Share Posted July 14, 2021 While I was on a roll Nipper’s Nipper was long over due some tlc and had suffered some damage around 18 months ago. The inside was not too bad so a rub down with 320 grit and two coats of varnish applied. The outside was getting quite bad so strip back to the wood and 6 coats of Ravilakk followed by 4 coats of Brava. The small hole was cut back to 3mm thick (half the plank width) then a small patch glued in with epoxy this needed to be flush with the plank as sanding would go through the veneer, the grain sadly does not match but once the rope fendering Is fitted should not be too noticeable. 1 1 Quote Link to comment Share on other sites More sharing options...
Lulu Posted July 14, 2021 Share Posted July 14, 2021 Are you getting a nameplate for Nipper’s Nipper’s Nipper and will the trio be available for judging at the Wooden Boat Show? Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted July 14, 2021 Author Share Posted July 14, 2021 5 minutes ago, Lulu said: Are you getting a nameplate for Nipper’s Nipper’s Nipper and will the trio be available for judging at the Wooden Boat Show? 1 2 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted July 14, 2021 Share Posted July 14, 2021 He's chuffin showing off yet again, that's what it is. What with his exemplary canoe building skills, first class varnishing and now graphic applicating Is there no end to this mans talents? Griff 1 Quote Link to comment Share on other sites More sharing options...
Polly Posted July 14, 2021 Share Posted July 14, 2021 No 😊 1 1 Quote Link to comment Share on other sites More sharing options...
AndyTBoater Posted August 2, 2021 Share Posted August 2, 2021 Nipper alert!! Just seen her trundling through Wroxham Bridge, flotilla of little nippers in tow, looking gorgeous in the early afternoon sun. Lots of admiring comments from all the punters standing around eating chips and feeding the " big white ducks" I am now massively envious. 1 Quote Link to comment Share on other sites More sharing options...
