RumPunch Posted November 27, 2023 Share Posted November 27, 2023 https://www.edp24.co.uk/news/23950221.boat-sinks-norfolk-broads-village-reedham/ Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 27, 2023 Share Posted November 27, 2023 Oops! I know who's that is, he did indeed live on it. 7 Quote Link to comment Share on other sites More sharing options...
Andrewcook Posted November 27, 2023 Share Posted November 27, 2023 How the Hell did that Boat Sunk at Reedham Quayside? Was it the Bildge pump gone? I do hope the owner of that private Boat is fully Insured. 1 Quote Link to comment Share on other sites More sharing options...
Chelsea14Ian Posted November 27, 2023 Share Posted November 27, 2023 All very sad.Hope all safe and the boat can be saved. 1 Quote Link to comment Share on other sites More sharing options...
DaveRolaves Posted November 27, 2023 Share Posted November 27, 2023 Was it the Bilge pump gone? - could well have been - after a time the bilge pump would have drained the battery and would not work any more - especially if the batteries were not in a good state to start with. 1 Quote Link to comment Share on other sites More sharing options...
YnysMon Posted November 28, 2023 Share Posted November 28, 2023 With the water levels having been so high recently, might there be another explanation? 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted November 28, 2023 Share Posted November 28, 2023 the news report suggested it had caught on the quay heading, and with nobody around could easily have tipped and put a gunwale under. 4 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 28, 2023 Share Posted November 28, 2023 It only takes the wrong skin fitting under water to start a syphon in, more likely on a hire boat than a sea capable boat but still very possible, also bobbing on the quay edge can cause damage to hull or stern gear especially on that concrete edge. Whatever happened its not good news for the owner, hope he gets something sorted. 3 Quote Link to comment Share on other sites More sharing options...
Troyboy Posted November 28, 2023 Share Posted November 28, 2023 2 hours ago, Smoggy said: It only takes the wrong skin fitting under water to start a syphon in, more likely on a hire boat than a sea capable boat but still very possible, also bobbing on the quay edge can cause damage to hull or stern gear especially on that concrete edge. Whatever happened its not good news for the owner, hope he gets something sorted. I might be being a bit thick Smoggy, but what do you mean by the wrong skin fitting. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 28, 2023 Share Posted November 28, 2023 26 minutes ago, Troyboy said: I might be being a bit thick Smoggy, but what do you mean by the wrong skin fitting. Any skin fitting that can let water into the hull, may be a bilge pump outlet that can syphon back once submerged or a sink drain, once the boat tips far enough they are all wrong skin fittings if open at the other end. Also engine bay air vents can be the problem if in a bad position, they are all fine at a normal attitude but when hulls are tipped to the wrong extent they are seriously comprimised. Bilge pump outlets can be fine submerged with a good goose neck up to the point the pump kicks in, then the pipe gets filled with water and the syphon can begin unless the gooseneck has a vented loop, my boat would fall foul of these issues for sure and it has taken way more angles that the broads can throw at it in regular use but one hooked on the edge up it's a different matter. 2 Quote Link to comment Share on other sites More sharing options...
Admiraldingley Posted November 28, 2023 Share Posted November 28, 2023 10 hours ago, Smoggy said: It only takes the wrong skin fitting under water to start a syphon in, more likely on a hire boat than a sea capable boat but still very possible, also bobbing on the quay edge can cause damage to hull or stern gear especially on that concrete edge. Whatever happened its not good news for the owner, hope he gets something sorted. The warden warned me a few weeks back that it was going to be a high tide, but I fell asleep before sorting out the fenders, it took some gouges our of the paintwork, it made me realize just how easy that concrete can gouge chunks out of fibreglass. I saw one couple had made a custom line that they tie from one post to the next, it has fenders & weights that just drop over the side. I picked up some scrap fenders from Doug the facebook fender man so I can make one. 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 28, 2023 Share Posted November 28, 2023 For places like reedham I have hollow rigid plastic pipe that slot together and fix to the handrails, it's 63mm mains water pipe with stainless spigots at the joins, the rope goes through to the bottom and they don't float. They fold up for stowage but give protection from handrails down to 18" below chines so on high tides ensure the boat stays over the river. Hard plastic is far better than concrete. 2 Quote Link to comment Share on other sites More sharing options...
Troyboy Posted November 28, 2023 Share Posted November 28, 2023 Thanks Smoggy. It makes sense now. I've always thought of single bilge pumps as having all of your eggs in one basket. Do owners get them changed regularly or are they very reliable for a long time. I never liked mooring at Reedham in my own hoat because of the concrete quayside. Quote Link to comment Share on other sites More sharing options...
dom Posted November 28, 2023 Share Posted November 28, 2023 6 minutes ago, Troyboy said: Thanks Smoggy. It makes sense now. I've always thought of single bilge pumps as having all of your eggs in one basket. Do owners get them changed regularly or are they very reliable for a long time. In my experience, surveyors tend to recommend fitting a high capacity manual pump in addition to an automatic electric. I always found that a bit odd - if a pump's going to fail, inevitably, it's more likely it'll do so when the boat's unattended and there's no-one to man the 2nd pump. The most sensible recommendation I've seen is to fit a second auto pump, with a float switch which triggers a fair bit higher than the main pump. Cable it directly to the starter battery, using slightly over-rated cable. Add a fuse rated just below the cable capacity, ensuring it's significantly higher than the current rating for the pump. That seems to provide a couple of benefits - a fail safe pump, which will keep running irrespective of any main bus or switch panel failure - but also a secondary pump which will join in parallel with the main pump if you suffer a more substantial leak. The overcapacity cable and high rating fuse is intentional, so the unit tends to keep running even if overheating. If your boat's sinking, the slight risk of fire is probably not worth worrying about! Given the relatively small cost involved, anything I own is getting something along those lines. Years ago, I saw an all female crew on a hire boat hole their hull on wooden stakes near Horning church and it's amazing how quickly a boat can go down. Dom Buckley also recommended "a pair of stout buckets should be carried at all times" on one survey, which I think is fairly sound advice too. 2 Quote Link to comment Share on other sites More sharing options...
Troyboy Posted November 28, 2023 Share Posted November 28, 2023 46 minutes ago, dom said: In my experience, surveyors tend to recommend fitting a high capacity manual pump in addition to an automatic electric. I always found that a bit odd - if a pump's going to fail, inevitably, it's more likely it'll do so when the boat's unattended and there's no-one to man the 2nd pump. The most sensible recommendation I've seen is to fit a second auto pump, with a float switch which triggers a fair bit higher than the main pump. Cable it directly to the starter battery, using slightly over-rated cable. Add a fuse rated just below the cable capacity, ensuring it's significantly higher than the current rating for the pump. That seems to provide a couple of benefits - a fail safe pump, which will keep running irrespective of any main bus or switch panel failure - but also a secondary pump which will join in parallel with the main pump if you suffer a more substantial leak. The overcapacity cable and high rating fuse is intentional, so the unit tends to keep running even if overheating. If your boat's sinking, the slight risk of fire is probably not worth worrying about! Given the relatively small cost involved, anything I own is getting something along those lines. Years ago, I saw an all female crew on a hire boat hole their hull on wooden stakes near Horning church and it's amazing how quickly a boat can go down. Dom Buckley also recommended "a pair of stout buckets should be carried at all times" on one survey, which I think is fairly sound advice too. Thanks dom. I thought that a second standby pump would be a necessity for piece of mind. Your comment about 2 stout buckets made me smile. I need 1 stout back to use them. Quote Link to comment Share on other sites More sharing options...
Admiraldingley Posted November 28, 2023 Share Posted November 28, 2023 54 minutes ago, dom said: Given the relatively small cost involved. That's a good idea, now I know what I'm going to be doing with the two spare water pumps I pulled out of my scrap tourer. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 28, 2023 Share Posted November 28, 2023 A caravan water pump will block very quickly shifting bilge water, there's always other crud in there, a proper bilge pump is a different beast. No matter how bad your back is Troyboy you'll bail pretty hard when water is coming in. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted November 28, 2023 Share Posted November 28, 2023 During ‘B.A’s restoration we lifted all the hull skin fittings higher up from the waterline (apart from the raw water engine coolant intakes obviously) Then for our sea trip to the Thames I fitted in line non return valves for the two bilge pumps. Since then we have added two float switch bilge pumps. There is no way of switching these off other than disconnecting the wiring (fuse protected) The engine raw water intakes are protected by two s/steel sea cocks 90deg handle type The exhaust has a collector flap valve chamber just inboard of the Transom. I’ve done what I can Griff 3 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted November 28, 2023 Share Posted November 28, 2023 Btw - The above is posted for info or those that feel the need Griff 1 Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted November 28, 2023 Share Posted November 28, 2023 I have the original bilge pump on Whitey, it is mechanical one with the diaphragm visible and separate float, it is noisy. I check it every visit to make sure it works. I have wired it to the inverter battery as that is rarely used. I fitted a second high volume modern bilge pump and float lower down and wired that to the double house batteries. Both are fitted with non return valves. The Sheerline had a jammed float and flat battery during my survey, this is now replaced and wired to the new double house bank. I don't think pumps are an area to save money on. 3 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted November 29, 2023 Share Posted November 29, 2023 I used to keep a fender board in the lazarette on Cerise Lady if heading south during spring tides , sadly no stowage on Pipedreams 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted November 29, 2023 Share Posted November 29, 2023 48 minutes ago, CambridgeCabby said: I used to keep a fender board in the lazarette on Cerise Lady if heading south during spring tides , sadly no stowage on Pipedreams Could you make a hinged version for easier stowage? Quote Link to comment Share on other sites More sharing options...
annv Posted November 29, 2023 Share Posted November 29, 2023 When i had my new boat CE certified i had to have three bilge pumps one auto. one electric Mobile one and a manual operated one adjacent to the auto one. if the boat sinks while you are not on board it's not life threating, if on board you have two additional pumps that are manually operated. John 2 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted November 29, 2023 Share Posted November 29, 2023 1 hour ago, Smoggy said: Could you make a hinged version for easier stowage? Katie has already managed to fill all , and I mean all, stowage 5 Quote Link to comment Share on other sites More sharing options...
annv Posted November 29, 2023 Share Posted November 29, 2023 Hi Cabby I use two lengths of plastic hose enclosed in foam sheath with a rope at one end these sink down vertically well below water line and will stop me over topping when tides are over topping the bank/Quay heading they take up very little space as they are only 2 inches dia and two foot long plus rope and stop the hull from scratching long enough until tide drops. John 1 Quote Link to comment Share on other sites More sharing options...
