OldBerkshireBoy Posted September 22, 2021 Share Posted September 22, 2021 Hi wise ones, I have a friend down south who is having a hard time removing stubborn deck paint on a grp deck, now I am not sure what he has tried (and he has done it before) so welcome any suggestions what so ever. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
grendel Posted September 22, 2021 Share Posted September 22, 2021 Sandpaper, or a scraper, a lot of recommendations for removing products will depend upon the paint type, if its an epoxy paint that has dried well, then finding a product that will remove the epoxy and not the gelcoat may not be so easy. 2 Quote Link to comment Share on other sites More sharing options...
annv Posted September 22, 2021 Share Posted September 22, 2021 Hi Nitro mores is the industry product not sure on fibre glass but if you want to remove sign writing from vehicle cellulose finishes Oven off will do this without damaging the vehicle paint finish, or last resort elbow grease works well and is safe. John Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted September 22, 2021 Share Posted September 22, 2021 I’m a good paint remover Griff Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted September 22, 2021 Share Posted September 22, 2021 I would have thought carefully use of an automobile tcut or a good wet and dry paper would do it , both obviously used with care Quote Link to comment Share on other sites More sharing options...
unclemike Posted September 22, 2021 Share Posted September 22, 2021 1 hour ago, BroadAmbition said: I’m a good paint remover Griff thought your driving had improved? 3 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted September 22, 2021 Share Posted September 22, 2021 On varnish I mix the following and rub down with wire wool:- One part methylated spirit, one part white vinegar, one part white spirit, half part linseed oil mix well and pour into a pant kettle or dish a little at a time. Regards Alan Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted September 22, 2021 Share Posted September 22, 2021 I often think I should get a pant kettle to boil my smalls when they’re being laundered 1 Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted September 22, 2021 Share Posted September 22, 2021 There is a GRP safe paint remover that I can't remember the name of. That's because I found it simply didn't work. I will have it in one of my units somewhere. I could probably lay my hands on it if you wanted to try it. I have painted a lot of boats and there is no substitute that I have found for abrasives. Sorry, I know that's not the news you wanted. DO NOT USE NITROMORS. 2 1 Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted September 22, 2021 Author Share Posted September 22, 2021 4 hours ago, annv said: Hi Nitro mores is the industry product not sure on fibre glass but if you want to remove sign writing from vehicle cellulose finishes Oven off will do this without damaging the vehicle paint finish, or last resort elbow grease works well and is safe. John You dont mean this do you. https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiEjq6FmZPzAhVvgFAGHcBPDCEYABAFGgJkZw&ae=2&ohost=www.google.com&cid=CAESQOD2A9LlRzTTic9emAw49FX5zVqC1hieDukh6oZ4VeYXxoX7-KQCTrGC5Wvb6K9JvYV2kDbNmqlIoHKffuOyLOI&sig=AOD64_1GkUF2RcJMOMGBmNe9lmqlDnsajA&ctype=5&q=&ved=2ahUKEwiTwKaFmZPzAhXVPsAKHedfDRwQ9aACegQIARB3&adurl= No of course you didnt. Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted September 22, 2021 Author Share Posted September 22, 2021 3 hours ago, CambridgeCabby said: I would have thought carefully use of an automobile tcut or a good wet and dry paper would do it , both obviously used with care and will take forever to remove the existing deck paint but thanks. Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted September 22, 2021 Author Share Posted September 22, 2021 24 minutes ago, Oddfellow said: There is a GRP safe paint remover that I can't remember the name of. That's because I found it simply didn't work. I will have it in one of my units somewhere. I could probably lay my hands on it if you wanted to try it. I have painted a lot of boats and there is no substitute that I have found for abrasives. Sorry, I know that's not the news you wanted. DO NOT USE NITROMORS. He is an experianced boat painter so wouldnt use Nitromors nor would he simply flatten old paint and apply new paint but whatever this top layer is it aint playing ball with his normal paint remover and scraper plus the clock is ticking so any ideas are much appreciated guys n gals. Quote Link to comment Share on other sites More sharing options...
Keebz Posted September 22, 2021 Share Posted September 22, 2021 There is no easy way, various grits down to smooth (without sanding the decks away🤣) have plenty of tack clothes and some relaxing music Quote Link to comment Share on other sites More sharing options...
Vaughan Posted September 23, 2021 Share Posted September 23, 2021 If the deck has been painted with a two part paint such as International 709 and sanded beforehand to give a "key" to the paint, you will be lucky to get it off. This sort of paint is a gel coat in itself and will have bonded thoroughly with the original gel. I am afraid painting over GRP should be considered as a last resort, especially if you try to change the colour! All that happens is the next time you go under a tree branch, the scratches show through the original colour. I haven't seen the boat, but if you can't get the paint off it probably isn't going to come off. Sand thoroughly to give a key, and paint over. Once you have started painting GRP you have to keep renewing it regularly, just like a wooden boat. 3 Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted September 23, 2021 Share Posted September 23, 2021 12 hours ago, OldBerkshireBoy said: He is an experianced boat painter so wouldnt use Nitromors nor would he simply flatten old paint and apply new paint but whatever this top layer is it aint playing ball with his normal paint remover and scraper plus the clock is ticking so any ideas are much appreciated guys n gals. I didn't say I wouldn't flatten old paint and recoat. You have to be careful. You need to know what type of paint you have on the boat already before applying a new paint. 2 pack paints have an exothermic curing process. This means that they use a chemical reaction to generate heat. The result is a better bond to a properly prepared substrate and a longer life with greater scratch resistance. The problem is that the heat generated in the curing process can act like a hot-air paint stripper to an underlying single-pack paint. So, if you don't know what the existing paint is, applying two pack is a gamble unless you remove all the paint. Single pack paint can be applied to any surface but isn't as tough. Deck paint will need renewing regularly, especially if you don't make a good job of the prep and this is VERY hard on GRP decks with the anti-slip moulding in the gel as it's virtually impossible to get the paint out of the valleys without a sharp pick and a month of sundays at your disposal. A very high power pressure steam cleaner is often capable but few people have such an expensive machine (a good boat yard will have one though), but these can strip paint you want to leave in place too. Nothing that's worth-while is easy. 2 Quote Link to comment Share on other sites More sharing options...
RumPunch Posted September 23, 2021 Share Posted September 23, 2021 I used Peelaway 7. It's a paste you trowl on, cover with a poly sheet, leave and peel off. You will probably then have to wash off any residue. My 1985 yacht was on it's third non slip coat. The stripper removed the top 2 totally, and about 60% of the original first layer - more than sufficient for me to appy KiwiGrip Oh - and I belive you can get trial pots if you want to run a test 1 Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted September 23, 2021 Share Posted September 23, 2021 I was going to start using a different deck paint product last year. I don't recall the name of it now, but it was similar to this: https://www.foxschandlery.com/kiwigrip-non-skid-paint-deck-system?ps=MjIzPTg5NDgmMjIyPTg3Nw==#223=8948&222=877 The reason I didn't was a discussion with the UK distributor who had been having some supply problems and told me that the shelf life of the product was pretty limited, so if I was to buy a few tins, they would need to be used within a certain time and if not would be spoiled. For me, that was a certain money loss as I could not, at the time, afford to get multiple decks prepped and sorted quickly. However, it might be an idea for your deck project. I am not sure that George at Ludham Bridge Boatyard isn't using something similar. 1 Quote Link to comment Share on other sites More sharing options...
RumPunch Posted September 23, 2021 Share Posted September 23, 2021 30 minutes ago, Oddfellow said: I was going to start using a different deck paint product last year. I don't recall the name of it now, but it was similar to this: https://www.foxschandlery.com/kiwigrip-non-skid-paint-deck-system?ps=MjIzPTg5NDgmMjIyPTg3Nw==#223=8948&222=877 The reason I didn't was a discussion with the UK distributor who had been having some supply problems and told me that the shelf life of the product was pretty limited, so if I was to buy a few tins, they would need to be used within a certain time and if not would be spoiled. For me, that was a certain money loss as I could not, at the time, afford to get multiple decks prepped and sorted quickly. However, it might be an idea for your deck project. I am not sure that George at Ludham Bridge Boatyard isn't using something similar. The great thing about KiwiGrip is it's acrylic, so if you buy white you can simply tint it just about any colour you want with easily available dyes. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted September 23, 2021 Share Posted September 23, 2021 I seem to recall using something called strippit or similar on grp without causing any problems but it had to be left on overnight to do any good, this was a long time ago though. Definately not regular nitromors. Quote Link to comment Share on other sites More sharing options...
