oceandawn Posted May 25 Share Posted May 25 Hi Does anyone have experience of a reversing camera.We have a Princess 33 moored in a really difficult spot in our marina.So much so that we are wary about taking her out and thought a camera might alleviate some of the stress.Any thoughts would be apprecIated. Many Thanks Pauline and Keith Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted May 25 Share Posted May 25 I purchased one of E*** which you mount magnetically (adhesive plate included) and it links with my phone screen via Bluetooth , use it when solo helming and find it very useful Quote Link to comment Share on other sites More sharing options...
oceandawn Posted May 25 Author Share Posted May 25 Hi Does that mean no wiring?Not sure what E*** means.Where did you buy it please? Thank you Quote Link to comment Share on other sites More sharing options...
Maxwellian Posted May 25 Share Posted May 25 Think bay might be after the E Quote Link to comment Share on other sites More sharing options...
Wussername Posted May 25 Share Posted May 25 You do not need a reversing camera. Just be aware or your surroundings. Take it slowly. Stop if necessary, look around and then reverse. And then, most importantly perhaps most important, do not under any circumstances put too much energy into your boat. A liitle nudge of the throttle, and I really mean an intercerceptable nudge in forward gear to bring the stern around. And then a nudge in reverse. Have a look, perhaps try putting the wheel on the other lock. If necessary. But calmly. Same process. Speed does not and never has been the problem or an issue whatever you have been told. It is all about putting energy into your boat, or controlled energy, when carrying out intracut manoeuvres. A little nudge here and a little nudge there. It is sometimes all that is needed. A camera will not teach you that. Buy one if you wish. It will undoubtedly show you where you went wrong. Speed and energy. The former often mentioned, energy into a boat on mooring or leaving a mooring hardly mentioned and there is a difference. 1 Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted May 25 Share Posted May 25 I fitted hard wired rear and side cameras on Whitey around 12 years ago to cover blind spots. I wouldn't be without them. On the topliner they are essential. 5 Quote Link to comment Share on other sites More sharing options...
Ray Posted May 25 Share Posted May 25 2 minutes ago, ExSurveyor said: I fitted hard wired rear and side cameras on Whitey around 12 years ago to cover blind spots. I wouldn't be without them. On the topliner they are essential. I did the same on a previous boat, a Bounty 30 and found them invaluable, it's not about helming in reverse it's about seeing clearly where you are helming in reverse! 3 Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted May 25 Share Posted May 25 I would probably go for wireless if fitting now, depending on how much use the boat will get, charging may be a hassle compared with hard wired. Hard wired can take a lot of effort to run the cable from the back to the helm. 2 Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted May 25 Share Posted May 25 This is the one I’ve got , the higher you can mount it the better , it’s rechargeable via usb and the charge lasts for about 5 hours but I only used to switch it on when needed , and remember to take it off when moored up (magnet holds it securely to the provided plate if you haven’t a suitable surface to mount it) 4 Quote Link to comment Share on other sites More sharing options...
Wussername Posted May 25 Share Posted May 25 Fair comment. And the hire boats ? Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted May 25 Share Posted May 25 We've got a bath tub and I fitted a hard wired jobby bought from yeba (anagram) Really good when single cruising leave it on all the time just incase we aren't up to the speed target and something creeps up behind us it shows their bow wave before them. Also really good for safety, as the ones which are fitted to cars and lorries always worth a look before going back and checking just incase someone has entered your path . No mirrors on our tub so very useful to us Kindest Regards Marge and Parge 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted May 25 Share Posted May 25 most cheap action cams nowadays can connect to a phone via bluetooth, i have several of those cameras purchased from lidls for about £30 each Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted May 25 Share Posted May 25 eBay, eBay, eBay. There, I have said it out loud 3 Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted May 25 Share Posted May 25 2 minutes ago, ExSurveyor said: eBay, eBay, eBay. There, I have said it out loud Was that a buy it now or best offer Kindest Regards Marge and Parge 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted May 25 Share Posted May 25 Build one of android head units into the helm and link cameras and it can be a full nav system as well as music machine. Quote Link to comment Share on other sites More sharing options...
NotDeadYet Posted May 26 Share Posted May 26 12 hours ago, MargeandParge said: I fitted a hard wired jobby This would puzzle Billy Connolly 1 Quote Link to comment Share on other sites More sharing options...
annv Posted May 26 Share Posted May 26 Hi Keith Do you have outdrives or inboard and is your boat twin engined or single as any of these combinations may be the problem with maneuvering in tight spots on a 33. John Quote Link to comment Share on other sites More sharing options...
Mouldy Posted May 26 Share Posted May 26 5 hours ago, NotDeadYet said: This would puzzle Billy Connolly How could he weech one if it was hard wired, I wonder? 1 Quote Link to comment Share on other sites More sharing options...
Smoggy Posted May 26 Share Posted May 26 @annv I think the op's issue is vision not handling, it doesn't matter how well you helm the boat if you can't see where you're going. 1 Quote Link to comment Share on other sites More sharing options...
oceandawn Posted May 28 Author Share Posted May 28 Hi Thanks for all your responses. I knew some one would know. The wealth of knowledge on this Forum is extensive. Anv . It is twin engine inboard. The vision is not good. Smoggy . How true. We are not the worst helm but not the best either even after many years of boating .We are at Cove and it is pretty tight . The only consolation is that the majority of berth holders do have some issues. We have been out at the weekend and managed to get it back in with using the ropes a fair bit, so O.K. but not ideal. We have an extensive Furuno navigation system. Does anyone know if a camera could be integrated into this? Many Thanks Keith Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted May 28 Share Posted May 28 Have a wireless Auto-Vox camera and monitor brought of the web waiting to be fitted as I have zero rear vision when on my own. Took power for the camera from the nearest fusebox and plugged the monitor into a cigarette lighter socket, image is cystal clear even in night vision and image on the screen can be inverted if requied. 2 Quote Link to comment Share on other sites More sharing options...
annv Posted May 28 Share Posted May 28 Hi Keith Are you reversing with the canopy up ?, if so you would need a camera on each stern corner unless you elevated it on a pole attached to the roof. Just a thought as i thought the view through the patio doors was good. Have you thought of rear view mirrors, this is what I have, gives a uninterrupted view down both sides when mooring ect. John 1 Quote Link to comment Share on other sites More sharing options...
MargeandParge Posted May 28 Share Posted May 28 It would mount on a pull pit rail or one of the car type ones on the transom. Kindest Regards Marge and Parge Quote Link to comment Share on other sites More sharing options...
oceandawn Posted May 28 Author Share Posted May 28 Hi John Yes the canopy is usually up.Would agree if it was down the vision through the patio doors would be better.Did wonder if we could fit a camera on the radar arch.It is comforting to know that more boat owners than us need assistance to stern moor.Don't feel so much of a numpty! Many Thanks Quote Link to comment Share on other sites More sharing options...
Lulu Posted May 28 Share Posted May 28 We are going to fit one. We have just been waiting for our aft canopy to be fitted then we can fit the camera around it. We have a blind spot on the starboard side, the boat crabs to one side and we dont have a bow thruster unlike on Luna. Basically we need all the help we can get 😂 1 Quote Link to comment Share on other sites More sharing options...
